Morning All,
My new forks have arrived and brought with them the question whether to star fangled nut or not. Is a Hope Head Doctor a better/safer solution or is there an alternative bung?
It really isn't.
Head doctor is for Alu and steel steerers only.
Buy a carbon specific fork bung.
It really isn’t.
But clearly is as your answer is not to use one and to "buy a carbon specific fork bung" instead...
I meant there is no question. It is not open to debate. There is no 'instead'.
My Cervelo which has carbon forks and steerer tube came fitted with a SFN.
Your Cervelo (hopefully) came with a metal insert that the SFN was already fitted to that was glued into the steerer tube. I really hope you don't just have an SFN fitted to a carbon steerer cos if you do the fork is a write off.
Cervelo use an insert glued in with sfn fitted. My go to carbon bung insert are
These
Solid and cheap 🙂
https://www.planetx.co.uk/i/q/FSPXFBUMK2/planet-x-carbon-steerer-fork-bung-mk-2
