I quite fancy trying some Magura brakes because I’m fed up with Shimano calipers leaking.
If I can avoid having to drop the motor to fit new hoses, that would fab.
Current hose is Shimano BH90 @ 2.1mm.
Looks as though the Magura hose is 2.3mm.
Do I need to suck it up and drop the motor? Or can I get away with reusing the Shimano hose?
Coming from 6120s, I know I’ll need to fit the Magura banjo at the caliper and and presumably a Magura olive at the lever?
Also, I’ve got half a litre of Shimano mineral oil in the garage. I’m going to need to bleed the new brakes, presumably, I’ll be ok to drain the system of the Magura fluid and refill with Shimano?
