Home Forums Bike Forum Bosch ebike display unit found on Rushup Edge
Viewing 9 posts - 1 through 9 (of 9 total)
  • Bosch ebike display unit found on Rushup Edge
  • peakblagger
    I found a Bosch display unit while cycling over Rushup Edge on Thursday (29th Dec) lunchtime, if you think it might be yours or know someone who has lost one please get in touch.
    Cheers.
    doomanic
    I’ve shared this post on emtbforums.com
    oceanskipper
    I’d love it if this ends with the unit being reunited with its owner…
    peakblagger
    Thanks, I’ve yet to go over to the dark side so unaware of their means of communication!
    kayak23
    I had to check as I was up that area on Thursday on a bosch eeb, but then the bike most likely wouldn’t work if the display had fallen off, plus I would have noticed. 😊
    Does it look like this…
    Or like this?
    doomanic
    I think the newer Bosch system will still operate without the Kiox attached.
    Ambrose
    I use a thin leash to tether mine to the headset, just in case. And reflective yellow taped it, just in case again.
    peakblagger
    It’s a kiox, the bottom picture
    dyna-ti
    If nobody claims it can i put dibs on it 😆  I think I only need the mount to get it running.
