TheArtistFormerlyKnownAsSTR
My legs and lungs will thank me for 2x – especially as it may also get used back home
I originally thought this when looking at gravel bikes – 2x would give me better range for winching up climbs….erm, nope.
That Boardman has a low gear of 30-32.
A typical 1×11 set-up will have a 40-42 low gear, which is virtually the same.
All you gain with 2x is closer spacing between ratios, which might be better for you on the road.
Well, that and a higher gear for downhills.
I was quite anti 1x on my Camino and then I tried it & realised it was fine. The ratios are a bit gappy and I’m normally a bit fussy about being in the ‘right’ gear. But, for some reason it bothers me less on the gravel bike, than I think it would do on my road bike.
I’ve always liked the look of those Boardman’s but imagine there are better deals to be had.
