Hi,
I’m back canvas opinion on the quite ridiculous explanation that I have just been given by a Cube dealer. To cut a long story short, the bearings in the chainstays were loose in the frame. After much complaining they agreed to change the chainstays. 6 weeks later I finally get the bike back, only now the two halves of the rear mech hanger are loose when you remove the wheel. I have a look myself and realise it’s because if you tighten it fully, the dropout half doesn’t sit in line with the axle and the axle cross threads when you tighten it. So that makes me think the recess in the chainstay hasn’t been machined properly. I talked to the dealer and they insist that this is by design! It’s designed to be a floating piece because apparently it’s impossible to build the rear suspension with tight enough tolerances to ensure that the dropout surface is completely square with the axle. So the fact that the rear mech is p1ssing in the wind whenever the wheel is removed is completely fine. That sounds like complete and utter BS to me. What do you guys think?
PS. I also suffered a snapped main suspension pivot bolt prior to this, so my opinion on Cube bikes couldn’t be any lower to be honest. Avoid at all costs.
