Walking poles
[Closed] Walking poles
I'll look at the review in Trail.
Like the idea of carbon fibre ones but I'm quite 'heavy' I wonder if they'll flex/snap under load.
The Karrimors seem great at that price...would prefer them over the Alpkits at £45 because of the locking system too...will reserve judgement til I read the review though.
Posted : 06/04/2015 11:05 pm
I'm not old and I've got poles for proper mountains - dodgy knees too. Couldn't care what I look like - poles are a better look than scooting down the mountain in tears on my arse.
As an alternative to Leki, consider Mountain King - made in the UK if that's important to you. Good value and very highly rated. I wanted the most compact ones I could get so have a pair of the Super Trekker Compact. They've got a twist-lock but it's never failed on me. http://www.mountainking.co.uk/menu/22/Trekking/
Posted : 07/04/2015 9:06 am
I bought a set of leki trigger sharks last year. They're the SPD version of treking poles in that you clip into them with a mitt, and they fold up much smaller than most poles. Didn't miss the adjustable length, just unclip and slide your hand down the pole on steep climbs. Plus you don't have that faff of either your pole length changing because you haven't twisted it tight enough, or untwisting failing to release the lock, that i've had with other poles. Plus you can just let go of them and they don't fall off your wrist if you need to do something else.
Posted : 07/04/2015 9:15 am
They'll bend under load, but mostly if you're using them badly. They shouldn't break under normal use, though I guess if you jam the tip in a crack and apply lots of force, they will probably snap - the lower tubes are by necessity, quite narrow.
Two tips: one is, before buying, to lock the poles in position and put your bodyweight through them to make sure there's no slippage. I've seen both cam and twist-lock version concertina if badly designed, not what you need if you're lowering yourself over a step for example with a lot of weight momentarily on the poles. And make sure you can adjust them wearing gloves if you're going to use them in winter. Personally I prefer the camming lever type closure, but people use twist-locks without dying on a regular basis.
Second, get some advice on how to use them properly. As with climbing axes, most of the load should go through the wrist loops rather than via the grip, which means holding them properly, which isn't always instinctive. You also need to adjust the length of the poles to work with the terrain - shorter on climbs, longer on descents.
There's a lot of guff out there about poles reducing the load on your legs/knees, by some totally unrealistic amount - think it through, do you really believe your arms are going to support 50% of your bodyweight for long? - but they're good for balance and stability, which in turn means you may walk more efficiently and avoid loading your joints and connective tissue in odd directions.
I'm not a huge trekking pole fan - I'm lucky I think, my legs have mostly survived without and I'm quite good on my feet - but they're brilliant for carrying heavy loads on uneven ground when you're so trashed from being up a mountain for days that you can barely walk in a straight line.
Blah... sorry to blather on.
Posted : 07/04/2015 9:23 am
I'm with those who just a stick, either selected en route or from a stash at home. Not as light as trekking poles, obviously, but better for slashing through brambles and scrub oak.
Posted : 07/04/2015 9:30 am
Sorry - not read the whole thread but some Leki poles on Sportpursuit at the min...
Posted : 07/04/2015 11:55 am
Anyone know if the Karrimor poles come with the baskets on? Can't tell from looking online...
Posted : 13/04/2015 8:47 pm
+1 with the damned brambles! Holly makes for a good, straight and tough stick, once it's dried out.
Posted : 13/04/2015 11:10 pm
Some girl coming out of London Bridge station last night was extending her poles before setting off across the hazardous crossing northwards over London Bridge.
I assume she made it OK...
Posted : 14/04/2015 10:11 am
The Karrimor poles do come with the baskets.
Posted : 14/04/2015 10:13 am
In case it helps - on a hot day I like to wear a pair of fingerless riding gloves with poles. They save friction with the strap.
Posted : 14/04/2015 10:17 am
Ended up ordering the Karrimor carbon fibre poles online at Sports Direct - £30 instead of £60.
Slightly concerned about them being couriered - especially when I found out it was Yodel as I've heard some real horror stories about them on here!
The whole process was way better than I thought it would be - regular text updates from SD and Yodel when they picked it up....delivered today (SD said it would be this coming Friday!) in a sturdy box - the poles themselves are really light and have nice adjustment. Pleasantly surprised and pleased all round really 🙂
Posted : 27/04/2015 8:18 pm
Just saw this.
Loads of younger runners use them here in mountain marathons
Interesting. When I did my one and only mountain marathon (if that's what it was) I'd have killed for some poles slogging back up the steep climb at the end. With that in mind, I took some on a long run/walk on merely undulating terrain in the snow when I was in Sweden and they were a bit of an annoyance.
I've decided they're only of use to me when going up something steep, or when carrying a heavy load. When carrying my daughter they encouraged me to walk much more quickly, but in running they didn't help at all.
Do you use them actually running or just on steep stuff?
Posted : 27/04/2015 8:30 pm
Page 2 / 2
