VW Golf mysterious ...
[Closed] VW Golf mysterious flat battery
[#6060683]
The Mrs's golf had a mysterious flat battery over the weekend. No lights, radios etc were left on. After a jump start it now starts fine, but since the flat battery the ABS and power steering warning lights are on, and the steering feels a little odd. Anyone know what would cause all this?
Something similar happened 18months ago where the ABS warning light came on after a similarly mysterious flat battery that the garage couldn't work out what was up. Faulty computer?
Posted : 24/03/2014 12:54 pm
something must be on to drain the battery ... maybe the glove box light, and over head light or something? or, if its like my very audi, theres water in somewhere and its sloshing around and shorting it. electrics are truely a PITA in cars.
Posted : 24/03/2014 1:00 pm
 iolo
How old is the battery? Maybe it has a dead cell. Is the alternator charging? Put a multi meter across the terminals. It should read 13 to 14 volts when then engine is running.
Posted : 24/03/2014 1:07 pm
battery was replaced last time it happened around 18 months ago
Posted : 24/03/2014 1:09 pm
this nay help.
[url=
the car guy[/url]
Posted : 24/03/2014 1:10 pm
we checked everything and we didn't find anything that was on. Even if there was theres nothing to explain the new warning lights?
Posted : 24/03/2014 1:11 pm
Check the alternator charging output.
Perhaps the warning lights are an indication of something amiss with charging?
Posted : 24/03/2014 1:31 pm
 sbob
creamegg - Member
Could be caused by the flat battery, might just need to reset the ECU (no idea how on your car).
One of my previous cars had a constant fault like this that my mechanic couldn't find the cause of, even after a new battery was fitted.
In the end I resulted to disconnecting the battery every night, was glad to see the back of the car when I px'd it.
Posted : 24/03/2014 1:44 pm
VAG cars have fusible links in connections made in the battery cover lid. They are 40/50 + amp links - These flat links develop cracks and lead to problems with power steering and ABS etc.
To check the links rub them with a small screwdriver , the hairline crack will open up if they exist - spares from any VAG dealer - sometimes there is a spare bolted in place - but it may be the wrong rating.
Posted : 24/03/2014 2:50 pm
Anecdotally, I've had one of those. Half the time it'd start perfectly, otherwise you'd get "click" and it was dead as a doornail.
Long story short, weeks of going through several mechanics and auto-electricians failed to diagnose a faulty rectifier on the alternator. Ended up taking it direct to Lucas who found and fixed it in under five minutes.
Dunno as that helps the OP though; sounds like a fault on one of those subsystems mentioned is draining the battery.
Posted : 24/03/2014 3:41 pm
from memory when had a touran turn steering wheel full lock both ways not sure if car was running or off but try both...prob was running.
this should sort it out !
Posted : 24/03/2014 4:28 pm
Have you had a full diagnostic scan done?
Modern cars use "smart" charging, and flat batteries can be caused by a huge number of things, from faulty modules not going to sleep as they should, to the SOC sensor failing and a million other things. One thing is for sure, you (probably) won't fix it by guessing!
Posted : 24/03/2014 4:38 pm
From personal experience get the fault codes read. had an 05 plate tdi that had these symptoms.
New ECU and some other major electrical component were the cure. Thankfully under warranty.
May not be this but worth checking.
Posted : 24/03/2014 7:23 pm
Again, how old is the battery, mine died overnight (6 year old car), no warnings at all but was sorted with a new battery. As for the warning lights, I checked all my fuses for another fault (removed & checked), the steering & electronic drive assist lights suddenly added to my woes (freaked me out). I took it for a drive & they cleared themselves within a mile or two.. Have you tried driving it far?
As above, had mine checked for other faults using the ecu reader, done by my mechanic m8 ( far from an electronics specialist)
Posted : 24/03/2014 7:42 pm
Thanks for the replies. Battery is around 18 months as i said. Done around 70 miles since yesterday, lights still on. Not had a chance to get diagnostic check done but on past experience these can be expensive with little or no results
Posted : 24/03/2014 7:45 pm
 muzz
Sounds like the fan belt, alternator belt or aux drive belt (however you call it) may have snapped meaning the alternator is not charging the battery and not powering the power steering properly. It is also likely the water pump is not working and your car may be in danger of overheating.
Look in the engine bay and see if it is still on the pulleys.
Posted : 24/03/2014 7:48 pm
I would check the Auxhilary belt tension, and the battery connection,then check for charging, Ideally you should charge up the battery from a mains supply before you do anything else.
Posted : 24/03/2014 8:13 pm
You'd know if the alternator wasn't supplying charge - red battery symbol.
The airbag and ABS etc lights are nothign to worry about - if you have a battery go flat, they come on, they should go off again after a bit. If you are near South Wales (or possibly London) I can read the fault codes for you and give you a few pointers.
Posted : 24/03/2014 8:18 pm
A simple check you can do, with a normal multimeter in current measurement mode is to measure the "sleep" current of the car. When you key off (ie turn off the ignition) some modules immediately go to sleep (like the engine controller for example) but others (infotainment, Nav, telematics etc) stay alive and only go to sleep after the car is locked (and generally after a delay post locking). You can measure the current draw from the battery say 15min after locking the car (you might need to "fake" a bonnet shut signal btw) to see if some modules are not shutting down and flatening the battery.
Posted : 24/03/2014 8:29 pm
Not on any of my cars, never had them come on and have had many duff batteries!
Posted : 24/03/2014 8:37 pm
It does on my VW 🙂 Other odd things happen too like the electric windows record faults along with half the rest of the car - clear them when the battery's charged up and they don't come back.
Posted : 24/03/2014 9:42 pm
Molgrips: How would you clear the faults? Someone recommended this...
http://www.amazon.co.uk/gp/aw/review/B005N5HN7A/R94MP2SSCYDFC/ref=mw_dp_cr/279-2773247-9128157?cursor=2&sort=rd
would that sort of thing be any good / worth getting? Based in cardiff btw
Posted : 25/03/2014 8:21 pm
I'm in Cardiff, I can pop over and help you.
As for that code reader - I don't know. Some code readers are quite crappy, I use VCDS which is a dongle costing £150 ish iirc, and some software for your laptop
Posted : 25/03/2014 9:21 pm
GF has a 06 golf. We had a similar issue with returning to a car with a flat battery. Turns out there is an issue with radios spontaneously switch on. Only noticed it when we had returned back to the car and could hear the music. VW replaced the radio as it was a well documented fault.
Posted : 25/03/2014 9:26 pm
 Dai
When you turn the ignition on does the red battery light come on the dash?
Posted : 25/03/2014 9:55 pm
At the moment the battery is not the problem as its been fine now since we jump started it, which probably rules out some of the causes mentioned. But obviously something made it go flat its just odd that it hasn't happened since the weekend, unless its to do with dodgy electrics. The power steering and ABS warning lights are still on and the steering does feel occasionally heavier than usual.
very grateful for your offer molgrips, and will take you up on that, ill send you an email
Posted : 25/03/2014 9:57 pm
 Dai
I'm not suggesting the battery is at fault. Gaining at the facts is part of a mechanics diagnostic process 😉
Posted : 25/03/2014 10:05 pm
That wasn't directed at you dai, just typing out aloud. Posted that before i saw your post. I think the battery light is on when the ignition is on but goes off when engine is on
Posted : 25/03/2014 10:09 pm
 Dai
It would be worth checking as it's quite common for the alternator load management wire to break which stops the light coming on at all. The battery can have just enough juice to run the car but load management starts shutting down high draw systems (electric PAS on yours?) as it can't regulate what's going on.
Posted : 25/03/2014 10:19 pm
I think this happened on our old Passat. The battery would appear to discharge over night, but in effect the alternator was barely charging. The nail in the coffin was a cold winter day with the fan, lights and blower on. The engine cut out and wouldn't restart. Charging check confirmed nowt between the terminals.
Rather than faff about we bought another car. I need to get another alternator and see if cures the charging issue. Its a bit of a faff as the front end of the car needs to come off to remove a single alternator bolt. Who designs stuff that dumb?
Posted : 25/03/2014 10:26 pm
Just been down to check, battery light on when ignition on, goes off when car starts. Also checked all the fuses, the fuse box in the engine were all fine, the fuse box inside the car had one broken fuse. This fuse wasn't listed in the car manual but should not be connected to the problem as these are fuses for interior stuff like seat heaters, blowers etc (i think).
Posted : 25/03/2014 10:37 pm
 Dai
In that case I'd start by pulling the fuse for the radio, give the battery a good few hours charge and check the voltages - off, idling and with a load on the battery. The lights on the dash will most likely need resetting with a diagnostic tool as they'll have been generated by the low voltage of the flat battery.
Posted : 25/03/2014 10:46 pm
Thanks for the input dai... Would i need to do that despite the car starting fine since it was jump started on sunday? Prob done over 100 miles since then.
Ill see if i can something to read the voltages. Any idea what they should be or will this be in the car manual or should i google it?
Posted : 25/03/2014 10:55 pm
