The tank of pink fl...
[Closed] The tank of pink fluid in the engine compartment of your car. What is it?
Tescos sells pink screenwash.
Posted : 31/10/2010 9:16 am
Step away from the Vee hickle!
Posted : 31/10/2010 11:04 am
surely if you can see where the hose(s) go it will give you a good idea what it is? brake hose is thin and not likely to go near the block or radiator but to the servo, water hose is squishy and goes to water pump and radiator, and power steering likely to go to the wrack or steering column.
failing that dip a rag in it and wipe it on the paintwork. if it changes colour it's brake fluid.
Posted : 31/10/2010 11:49 am
I once piped my screen wash system to the headlight jets only, filled the reservoir with muc-off and never had to wash the car again..
Posted : 31/10/2010 12:44 pm
Page 2 / 2
