Yeah, I don't really smell either. My gym kit is starting to suffer spending most of its time drenched in sweat and stuffed in a bag, but that's a different story.
The Southern Yeti - Member
Divagirl - It's got nothing to do with fitness, I'd say I'm pretty damn fit, sweating hasn't changed (might've got worse if anything?!).Some people are just hot! We're the lucky ones.
Glad you said about the fitness, I run and do military training, can't understand why I'm so hot!! probably need to shift a couple of pounds. I quite like the smell of fresh CLEAN sweat.
About yer gym kit - a spoon of napisan added to usual detergent seems to do the trick, brings my kit back to life.
The fitter you are, the more work you can do. The more work you do, the more heat you generate.. perhaps?
I've been told that sweating is good, because it means your body's good at controlling it's temperature.
Personally I find I perform very well in hot weather, and I love a good baking hot day for a bike ride. Loads of other people complain about hot weather.
What about the other sweaters on here?
I am a sweaty monster and have tried numerous wonder fabrics over the years. My path to wicking but warm lead me to a short sleeved polartec Powerdry Tee shirt, its absolutely the best performer of all my sporty type tops and is my go to base layer for boarding, riding and running.
Hmm I am afflicted by this too, currently I am just wearing a nike cotton vest type thing and my Charge Surface lightweight jacket/windcheater. Pretty much spot on in the current weather, may have to add a cycling top to the mix once it gets colder.
Id be screwed in the Arctic or somewhere where you have to be careful not to work up too much of a sweat.
Divagirl - wouldn't even think that carrying a bit of excess is the cause.
There is certainly some truth in that.... Specifically for things like spinning classes where the only thing determining how hard I push yourself is you. I reckon I could fill a cup with sweat after one of those.
Can't say I mind riding in the heat. Keeping hydrated is the main issue!
I could fill a pint glass with sweat I reckon after a hard indoor session.
My road bike has corrosion on the stem from all the sweat dripping on it from turbo sessions.
However more impressively my XC frame has corrosion on the cable mounts on the top tube due to sweat and that's only from racing out in the open air!
Also, I hardly ever have to stop on a ride for a wee - all spare moisture is sweated out 🙂
I have tried nearly all versions of base layer, and the Icebreaker one is no warmer than my HH ones, it just stinks less. I have merinos in all available weights (I ski as well) and the lightest is the one I use for cycling. I do use UnderArmour vests in the summer, but in winter they are very chilly when wet (which they are after 8-10 minutes).
Re. fitness/bodyweight. I find that is irrelevant in my case. I sweat just as much when in racing snake order as I do when carrying bit of timber.
A session on the lash the night before a ride certainly increases the flow.
Although I do drink fair bit when riding ( 1-2 litres on a 3-4 hr ride), I can manage without if I forget a bottle.
Also, I have never suffered from cramp, even in hot weather.
I have ridden up Mt. Tidy in Tenerife in 35 degrees, with the sweat literally squirting out of the vent holes in my shoes, and running down my arms. Ran out of water halfway up, and although I was pretty far from OK, I didn't cramp up.
Oh and whilst we're on the subject of hydration, my best ever semi-useless skill is being able to time drinking exactly right - so I finish my camelback within 5 mins of the end of a ride 🙂
Re merinos, they are often warm but lately they have started making really light weight ones. I have a tshirt in the thinnest ice-breaker weight, which is lovely. Especially as pyjamas 🙂
I bet you haven't! There are hundreds on the market.
