Suzuki drz400 super...
[Closed] Suzuki drz400 supermoto conversion
[#9371215]
As my dr doesn't really get used off road (nowhere to ride) I was thinking about having the front hub replaced onto an 18" rim and then fit road tyres front and rear, would this work?
Posted : 08/06/2017 10:39 pm
 colp
Useful info here:
[url= https://www.thumpertalk.com/forums/topic/695757-converting-drz400s-to-supermoto-help/ ]https://www.thumpertalk.com/forums/topic/695757-converting-drz400s-to-supermoto-help/[/url]
Posted : 08/06/2017 10:42 pm
I've just converted my drz400s to supermoto the cheap way by using wheels from a aprilia rs125 front wheel fits straight in but you need a disc adapter for the larger disc (£38 eBay) and a couple of washers for spacers rear wheel needs about 6mm taking of where the disc bolts on its a tight squeeze but it will go in.
Posted : 09/06/2017 10:09 pm
Posted : 09/06/2017 10:21 pm
17" road wheels not 18" or it'll get weird handling.
Plenty from the same or different manufacturers will fit easily or Ecels/Talons
I have excel/Talon on the CRF450R in 17"" with 250/400 cc sticky tyres due to it only weighing 97kgs fully fuelled.
You'll need to run then at very low pressures too - usually around 23-25 psi
Posted : 10/06/2017 8:40 am
10 years out of date there.
Posted : 10/06/2017 9:51 am
Out of date.? What a DRZ ? Yes your probably right but it's still more reliable then my KTM
Posted : 11/06/2017 9:03 pm
