Secondary glazing -...
[Closed] Secondary glazing - rough cost
[#7446574]
I'm thinking about getting secondary glazing fitted as I have two sash and case windows in my flat which is in a listed building so fitting double glazing will be very expensive.
Anyone had this fitted and have a rough guide to costs. Windows are pretty tall, one is 1.45cm wide and 287cm high., other is 97cm wide by 187cm high. I could probably fit the smaller one myself but the problem with the big window is that the window recess is sloping so no idea how that would fit.
Posted : 10/11/2015 11:42 am
Anyone?
Posted : 10/11/2015 1:45 pm
Can't help on costs unfortunately, ours had it fitted before we bought the place, I can say that it's really good though! Massively reduces noise and no drafts at all. I dare say it was reasonably pricey as it all looks pretty good, the units fit into slotted tracks as well as having magnetic strips, so very secure fit.
Posted : 10/11/2015 1:52 pm
Can't help on costs, but bear in mind you may still need Listed Building Consent for secondary glazing depending on where you are - it's required by some LPAs.
Posted : 10/11/2015 2:01 pm
Don't think I'll need listed building consent as when I bought the flat the interior of the building had been ripped out and replaced. Its modern inside so can't see that being an issue.
Posted : 10/11/2015 2:35 pm
Up to you, if it was my property I'd still check the local policy.
Posted : 10/11/2015 2:41 pm
I'd be interested in this too. I also have sash and case windows that are in reasonable condition although a bit draughty. I'm in a conservation area too and the cost of replacements is eye watering so I feel your pain. 🙂
[i]Up to you, if it was my property I'd still check the local policy. [/i]
I have already spoken to planning and had a long chat about it, she suggested secondary glazing and didn't mention it requiring planning.
And it's not just the cost of replacement, unless you present a case that the window is beyond repair then they won't give permission to replace. Condition is okay though, just the sill a bit rotten.
Posted : 10/11/2015 2:47 pm
May be of use to folk, they also have a number of other free guides that are handy if you live in an old property:
[url= http://www.historic-scotland.gov.uk/informguide-sashandcase.pdf ]Historic Scotland Inform Guide: Sash Windows[/url]
Posted : 10/11/2015 6:05 pm
