How would you do this. It's approx 600m2. It was/is a small woodland block left to over grow for the last 30 years. I've already cut the conifers away and have a chap coming into grind stumps out, but I'm going to be left with VERY uneven ground covered in Ivy and small stumps from saplings. Is there a machine that can simply rotorvate and sift? Oh if it helps I want to put a pump track in 😉
What is that? Is that just a land rake or has it some magic powers?
At a guess i'd say it was Bobcat related ?
Isn't the definition of a pump track "very uneven ground"?
Jim, yes you are right, but I've got to get the grass bit done first, then it's pump track round the edges. I found out what that thing was in the end as well as Forestry mulchers are what o could've done with at the beginning!
A simple rotovator will do the job, plus a lot of raking. Or get a guy in with a mini digger and a wide bucket fot a day to scrape it level.
