Posting images on S...
Posting images on Singletrack forum using Postimage
Posted : 15/09/2021 9:46 pm
A google image successfully posted, **** me! I want your babies SL2000!
Posted : 15/09/2021 9:47 pm
No need for all that. The forum software takes care of it. Copy the link, paste the link in the reply box. That’s it.
Sure, but I think the process differs if you are using the so called fancy editor or not. It certainly seems to when doing images.
Plus doing that short process, as I explained means you get the entire link as....the link.
It's often better to use link text instead so folks know what they're clicking on for example, or just so it looks better, should you care about that sort of thing.
There's more than one way to skin a cat
Posted : 15/09/2021 9:54 pm
Nothing to do with the topic. But I’ve had no update emails from this thread - despite subscribing until tonight! Suddenly they are flooding in, with every new post.
Lol its just the difference between subscribe and notify me of follow up replies via email checkbox.
Posted : 15/09/2021 10:16 pm
Posted : 31/12/2021 10:32 pm
Bloody hell, it worked! Thanks.
If you're on Windows, there's now a Postimage App that makes it even easier.
Posted : 31/12/2021 10:59 pm
So before I forget this, when posting from Flickr:
Use the desktop site
click the share button (curved arrow)
choose BBCode
choose size of image (large 728 x1048 seems ok)
copy the address
post only the part of the address that starts https and ends jpg into the image link box
Relax
Posted : 02/05/2022 11:50 am
TBH, that's the crux for all sites aside from the ones that go out of their way to prevent hotlinking.
Posted : 02/05/2022 11:59 am
choose BBCode
copy the address
I think with Flickr, it's all that you say except, you just paste the whole bbcode into the forum text box and that's it.
Don't put it in img tags. Just paste it all, hit Submit, and it works.
[url= https://live.staticflickr.com/65535/51689288493_8d5ecdc955_4k.jp g" target="_blank">https://live.staticflickr.com/65535/51689288493_8d5ecdc955_4k.jp g"/> [/img][/url][url= https://flic.kr/p/2mKB7Dc ]Untitled[/url] by [url= https://www.flickr.com/photos/79912681@N06/ ]blackteaonesugar[/url], on Flickr
Edit- yup, that works as above. Just make sure your image is set to public.
Posted : 02/05/2022 1:18 pm
oops ..
Posted : 02/05/2022 9:16 pm
Is that a sticker on that scratch joelowden?
Posted : 02/05/2022 10:56 pm
State of that lawn... 🙄
Posted : 03/05/2022 6:28 am
@Mrovershoot...... merely a light blemish 😁
Posted : 03/05/2022 9:20 am
 aide
Thread resurrection
@kayak23
Could you also do a tutorial on how to do the quote box? Probably very easy and shows how much of a luddite I am (have tried before but never works), can easily follow your guide lines though.
Posted : 21/07/2022 12:35 pm
Quotes are easy, just select the text you want to use, copy it, then tap the ❝ button at the top of the text box and paste the selected text after the cursor.
Then tap the return key a couple of times to get the cursor across to the edge of the box and continue typing.
Posted : 21/07/2022 1:38 pm
If you're not using the 'fancy editor' you won't see the " button. You'll have one that says B-Quote instead.
I just did it by pasting the text I wanted to quote into the reply box, highliting it and clicking the B-Quote button. I prefer the fancy editor though.
Posted : 21/07/2022 1:54 pm
You can just type [ quote ] ... [ /quote ] (only without the spaces) around text you want to quote also.
Posted : 21/07/2022 2:10 pm
Highlight the text that you want to quote and copy it.
Click into the reply box
Tap B-Quote button
Paste your text after the quote bracket thing that appears.
Then tap the B-Quote button above again.
When you hit Submit, the text you pasted will be in a quote box.
Posted : 21/07/2022 3:37 pm
 aide
Testing...
Posted : 21/07/2022 6:51 pm
 aide
Posted : 21/07/2022 6:53 pm
 aide
EDIT, I'll try later.....
Posted : 21/07/2022 6:55 pm
 aide
You can just type [ quote ] … [ /quote ] (only without the spaces) around text you want to quote also.
EDIT: Thank you @cougar
Posted : 21/07/2022 7:00 pm
EDIT, I’ll try later…..
Did you do the exact steps?
You should get the highlighted text as in the photo below before and after whatever text you paste into the box.
*Click B-Quote once
*Paste your text after it
*Click B-Quote again
That's it!
Posted : 21/07/2022 7:32 pm
iOS users can get this REALLY handy shortcut which literally does everything for you. Select photo from phone, click share, select "Upload to Imgur" and it does the rest then copies the link to your clipboard so you can paste it here. It takes seconds!
Easy!
Posted : 21/07/2022 8:16 pm
 aide
*Click B-Quote once
That’s it!
Yeah, tried it that way kayak, on my phone it does not show the block quote , just advances the typing space a bit (if that makes sense). Was the way I was trying before but thought it was something I was doing wrong, seems it just doesn't like it on my phone, don't know why
Posted : 21/07/2022 8:43 pm
Strangely I get an empty url
With Hotlink for forums option)
img src="http://" alt="" /
Removed the < >
And this is the Postimage listed ”direct link”
desc
(Spotted http and https in the forum created link, so removed one)
So that works well (using the forums “IMG” tool.
Posted : 20/12/2022 12:57 pm
Yeah, just tap 'Direct Link' which is usually the 2nd option down.
Tap 'IMG' in the Singletrack reply box menu, and paste that link into the box and hit submit.
Lauren has changed a bit.
Posted : 20/12/2022 1:02 pm
Bump
Posted : 01/01/2024 1:28 pm
Posted : 30/11/2024 6:17 pm
I haven't tried this before. Is this going to work, I wonder?
Posted : 30/11/2024 6:32 pm
Yes it did.
Posted : 30/11/2024 7:22 pm
Yes it did.
A "Thumbs Up" if there was an emoji.  It's a miracle!   Anyway, thanks for this.
Posted : 30/11/2024 8:02 pm
Ooh, mine worked but I'm not sure how I did it!
Posted : 30/11/2024 9:21 pm
Page 2 / 2
