balls of newspaper
jenga tower of kindling
topped with a split log
once that were all going, I used to pop on a couple of full sized logs
worked nicely in our old (very) small stove, it had excellent draw and would be going within a couple of minutes of lighting
Not read all of this but top vent open, bottom one closed.
[i]Never have bottom vent open when burning wood.[/i]
If it starts to struggle, put some scrunched up newspaper on the top of the logs and it will help draw up the flames again.
BigJohn - Do you know of a good place around Derby to get wood from?
I'm based in Derby, bought a big pallet of kiln dried wood a month back and the stuff is simply terrible! Doesn't light/burn very well and low heat derived from it too. Top tips of where to get wood from would be very appreciated
>Firelighters are for girls.<
This.
You need to learn how to roll your balls.........of newspaper.
Once you get that sorted things will become a lot easier. This does of course mean you need to source a steady supply of Telegraphs (or the Herald if you are in Scotland 😉
No. It was a hugely bad taste topical question.
Upside down method:
Two dry logs on the bottom
Firelighter/paper in
Largish heap of kindling on top of firelighter/paper
Small log on top of everything
[add a couple of lumps of coal if you feel like it]
Vent open, door ajar a tiny bit, cue fierce burning of kindling
Allow kindling to burn and watch with amazement as the bottom logs start burning, then plonk on another log when there's room
Close door, leave vent fully open
See above for best method 🙂
I think using split logs can be important at the start. The heartwood may be drier and more calorific than the sapwood, and the bark may slow down the heat getting through.
It worked! Used twice as much kindling as before, then small split logs. Got it nice and hot before adding large logs. Now burning nicely bang in the middle of ideal temp range on the thermometer
Thanks
Will try the upside down method tomorrow.
Let us know what you think
