Plastic grid as a s...
[Closed] Plastic grid as a shed base?
[#11679336]
Anyone able to advise on how plastic grids (like this) that you fill with stones are as a shed base? They're probably the best option for us as there is no access to the back garden without going through the house, but I wasn't sure if they would just create a different set of headaches!
Posted : 13/01/2021 10:42 am
When we moved house in October we needed a new small (6x4) shed and after inheriting a plastic one in the old house, went plastic again and obviously needed a base to put it on. Used something very similar to what you've linked but from B&Q.
Initial thoughts were that despite all the "easy to use" rubbish, it wasn't. Was a bit of a ballache to get reasonably flat and throughout I was wishing I'd just got some slabs and sand and created a base from that - it'd have been as much faff and definitely a LOT cheaper.
All that said, now its settled it works. Would I use it again? No - as said, slabs and sand base would have been as good in use and cheaper (we also only have access to the rear garden through the house).
Posted : 13/01/2021 11:28 am
Thanks, that's useful to know. The other complicating factors are that you need to climb steps to get into the house and I have a dodgy shoulder, so I was hoping to avoid slabs but it may be best to just get fairly small ones - probably cheaper as well.
Posted : 13/01/2021 11:54 am
I did ours with the interconnecting ones.
Bought a tonne bag of 10mm gravel, shovelled a load of it as a base then used the interlocked plastic to level everything off checking with a spirit level. Then filled in the gaps.
Would have been awful with bigger gravel and did take a little while to get flat but def took less time than laying slabs plus water drains through easily. Will be doing the same again for a potting shed we are going to put in
Posted : 13/01/2021 12:03 pm
I used it for mine and it was super easy and seems to have all stayed in place
Posted : 13/01/2021 12:04 pm
Yep, just laid one for a 10x7 shed. I leveled the area by eye first, then a quick check with the level. Once I was happy enough I laid a bit of stone, placed on the grid, leveled this all up again and filled in with 10mm gravel (I've got about 100kg left out of a 1 tonne bag and did an area of 9ftx12).
This is the one I used (8x6 off Amazon is £72)
https://www.amazon.co.uk/Garden-Greenhouse-Plastic-Included-Membrane/dp/B07K49XS8R/ref=asc_df_B07K49XS8R/?tag=googshopuk-21&linkCode=df0&hvadid=309904185356&hvpos=&hvnetw=g&hvrand=6209688141350604123&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006904&hvtargid=pla-696607311814&psc=1
Posted : 13/01/2021 12:25 pm
Thanks all, that's really helpful!
Posted : 13/01/2021 2:08 pm
