Recommend me a pump!! That is cheap as i will use it once ever!
[url= http://cgi.ebay.co.uk/Drill-Powered-Water-Pump-Pools-Floods-Leaks-Butts-/350308912288?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item519009cca0 ]PUMP[/url]
EDIT [url= http://cgi.ebay.co.uk/SELF-PRIMING-BARREL-PUMP-HAND-ADJUSTABLE-OIL-FUEL-/270610890009?pt=LH_DefaultDomain_3&hash=item3f01aa7d19 ]PUMP 2[/url]
You can get them ones that attach to the drill,they're cheap. Not sure how well they will pump oil!
EDIT: Bugger,to slow.
concerned that it would burn my drill out, what sort of volume do they shift?
should also say it needs to have 4.5ft of hose/pipe on the inlet side
Dunno pump 2 might be better.
Drac - cheers for that. Had given it some thought but at £45 for a 15 minute job its like a very expensive sex line, it can also be done with a bit of thinking and a hand job and cost far less!
Probably other ones on available though, we use to have the hand pump like the ones lipseal linked for the vehicle cleaning fluid. Shifting 250L of oil with one of those will take a lot of work.
Get the local scouts in on bob-a-job!
