Mystery Chamber in ...
[Closed] Mystery Chamber in Garden
[#10538526]
Took up some decking and found this mystery chamber in my garden.
Concrete lined, around 5M deep, 2m diameter, solid floor. No pipes in or out except a blue one that come up out of the floor and is open.
Any ideas??
chamber
Posted : 17/03/2019 6:17 pm
Pics? (Or is that link that won’t open on an iPad? 🙃)
Posted : 17/03/2019 6:24 pm
porn chamber?
Posted : 17/03/2019 6:27 pm
I was going to say Ice Chamber, but it looks too modern.
Access chamber for sewage perhaps? Check your deeds, might have access pipeworks on the plan.
Posted : 17/03/2019 6:35 pm
Zombie pit
Posted : 17/03/2019 6:36 pm
Looks like a standard precast concrete manhole chamber. Have you poked around in that silt?
Wondered if it could be some temporary during construction for dewatering maybe. Or maybe was meant to be a soakaway.....
Posted : 17/03/2019 6:38 pm
Septic tank that is now not needed due to a new main drain? At least that was the case at a friend's house in Walderslade, the council put in main drains after the house was built but before anyone moved in.
Posted : 17/03/2019 6:41 pm
Dropped a rock down and it sounded concrete at the bottom too.
There were some mines in the area a long time ago, maybe a vent?
Those manhole covers are heavy! It nearly fell down the hole taking me with it. I'm never lifting it again!!
@maccruiskeen to the thread!
(and a prod for updates 🙂 )
https://singletrackworld.com/forum/topic/whats-making-you-happy-heres-some-pics-of-my-garden/#post-7909734
Posted : 17/03/2019 7:15 pm
hahahahahahahahahahahahahaha!
Posted : 17/03/2019 7:32 pm
Is every square cm of the wall covered in shells forming ornate patterns?
Posted : 17/03/2019 7:38 pm
 Bear
Steps built into it suggest something worthwhile.
Was there any plans for rainwater harvesting?
Previous owner didn't happen to have a dog did he?
Posted : 17/03/2019 7:39 pm
No recent updates - did you see the film from inside?
A neighbour was passing with a JCB so got them to find the corners and chatting with an architect to get the ball rolling on planning
but been too busy blowing things up for the last 4 months so its on the back burner
https://singletrackworld.com/forum/topic/laying-cable/
Posted : 17/03/2019 7:42 pm
 ton
i have one of those in my garden.
about 9ft deep with a sewage pipe entering and exiting on the bottom.
in heavy rain it fills up halfway.
Posted : 17/03/2019 7:58 pm
No!
Posted : 17/03/2019 8:16 pm
Do you have a cellar, or similar? Is it near to the house?
It could be a sump to deal with flooding, but it's deep. The other end of the blue pipe will be attached to a pump if that's the case
Plastic pipe suggests it was used for monitoring water levels at some point?
Posted : 17/03/2019 8:20 pm
Recommend an Architect / Building designer Glasgow / Ayrshire ?
Blimey 🙂 I was about to make a hilarious "Blair Ditch" pun, and then realised I'd been beaten to it by 9 months.
Posted : 17/03/2019 8:28 pm
Double check whether there are any other pipes entering or leaving. That would give you a clue. There might be one/some right at the top, just below the cover slab which are difficult to see.
Posted : 17/03/2019 8:33 pm
What was there before your house was built? Looks like a very heavy cover for a back garden.
Posted : 17/03/2019 11:26 pm
Masterbatorium.
Posted : 18/03/2019 1:24 am
Its my gravel pit.
Check it out.
Posted : 18/03/2019 6:58 am
By the dimensions stated, it does sound waste water related. Who is your water utility - they may hold records of it on their GIS
Posted : 18/03/2019 8:24 am
My guess is that it's a holding and settling chamber for sewage and storm water and the blue pipe is an overflow, which would allow untreated sewage to escape straight into a nearby river.
It only takes 1mm of rain over that London for the sewers to overflow straight into the Thames, the new super sewer is supposed to prevent that. I remember finishing the London 100, shortened to 86 miles after biblical rain and the stink of raw sewage coming from the Thames along Chelsea Embankment was very strong.
Posted : 18/03/2019 9:56 am
My guess is that it’s a holding and settling chamber for sewage and storm water and the blue pipe is an overflow, which would allow untreated sewage to escape straight into a nearby river.
+1
Posted : 18/03/2019 10:03 am
Is it where you have kept your Austrian AuPair fort the last 18 years?
Posted : 18/03/2019 10:18 am
its a pumping chamber most likely.
Posted : 18/03/2019 11:17 am
It’s a picolax expansion tank.
Posted : 18/03/2019 3:20 pm
Did the OP go in for a look ?
What's down there
Posted : 18/03/2019 3:28 pm
Luckily I have a relative that works in the mapping section for the water company and they are looking into it.
House has been there about 6 years, before that it was farmland and before that there was a coal mine very close.
Not going back in as it's too risky lifting the cover on my own, particularly getting it back on. It almost fell down the hole a couple of times getting it lined back up.
These is a sewage/stormwater overflow outlet about 200M away. Maybe it goes there. Could always throw a rubber duck down then see if it pops out!
Posted : 18/03/2019 6:00 pm
