iPhone - how to set...
[Closed] iPhone - how to set contacts to ring on silent?
[#11072331]
I am sure I used to have a function on my iPhone that allowed you to have your phone on night mode (not receive calls etc), yet still allow certain contacts to ring you.
Example my Dad was taken ill last night. My Mum tried to ring me, obviously as the phone was on silent I didn’t hear it.
Does iPhone still have this functionality?
Thanks
Posted : 02/03/2020 9:46 pm
Do not disturb. Allow calls from favorites
Posted : 02/03/2020 9:49 pm
^^ As above. You can also allow calls from specified people and give them an individual vibrate rhythm.
Posted : 02/03/2020 10:30 pm
Don’t put it in silent.
Do not disturb as above.
Silent blocks everything
Posted : 02/03/2020 10:40 pm
Ok thanks.
My phone is on silent 99% of the time. Mainly because I can’t be bothered switching it on and off at work.
Just checked and if the phone is on silent the do not disturb function doesn’t work.
The only way I can allow phone calls is to allow Emergency by pass on the numbers, so then my parents could ring me in an important meeting during the day.
Doesn’t look an easy solution apart from me starting to remember to flick silent mode on and off... unless you can set a rule based on location (turn do not disturb on at work etc?)
Edit - just noted you can use DND by location, although it doesn’t state the location size. Where I work it’s prob 500m sq site!
Posted : 02/03/2020 11:06 pm
Don’t put it on silent.
Use do not disturb during working hours.
Add parents, etc to favourites and then they can call.
You’re making it hard for no reason by not reading what been suggested
Posted : 02/03/2020 11:13 pm
You've answered your own question.
Just go to the contact, ringtone, then activate emergency bypass. That will override the silent switch, you don't need to faff with dnd then.
Posted : 03/03/2020 2:19 am
There is also a 'repeated calls' setting which gives another way of overriding do not disturb.
Posted : 03/03/2020 1:08 pm
[i]Just checked and if the phone is on silent the do not disturb function doesn’t work.[/i]
I've just checked, and yes it does. At least it does in that it vibrates as I usually have it set when set to silent (i.e. all of the time). This is with DND on, and from a number in my favourites.
Posted : 03/03/2020 5:10 pm
b33 touched on it, I think there is a setting where if someone calls you twice in quick succession it will ring.
Posted : 03/03/2020 10:28 pm
