iDave diet, who don...
[Closed] iDave diet, who done it?
@ Jamie
Whilst only an estimate, there is some logic behind it
When I was 147kg I was 33% bf.
That means 48.51kg
I plan to loose another 30kg. Now 90% of the weight I have lost has been fat.... so of that 30kg I will loose 27kg will be fat.
Taking that away from the fat I'm currently karting around 48.51kg would leave approx 21.5kg of fat.
When I loose 30kg I will weigh 114kg and will have 21.5kg of fat (in theory)
Which is about 18% body fat.
Obviously all this is in theory, as those bf monitors are about as accurate as an unacurate object but I am using the same one, at the same time under the same conditions, so whilst not accurate they should be vaugely consistant.
Posted : 25/05/2011 10:49 am
Ian -
How tall are you?
Are you pretty hench?
Ignore bodyfat and look at hip to waist ratios instead.
Posted : 25/05/2011 10:51 am
TSY -
Using one of those machines, not accuratly using callipers so I realise that the above is not accurate.
6ft 4
and yes, I'm not small boned.
Posted : 25/05/2011 11:03 am
Fair do's.
Remind me not to give you any grief when you get down to your target BF%! For now I reckon I can still run away you f..... 😉
Posted : 25/05/2011 11:05 am
*considers ditching belt and buying braces*
*gets slightly teary at level of cruelty* 🙁
Posted : 25/05/2011 11:09 am
I've had to buy some new jeans and shorts at the weekend.. Now a 30 waist (which i haven't been since i was 18!)
Feels good 🙂
Posted : 25/05/2011 11:25 am
yup same here, though i've gone from 54inch - 42 inch
Posted : 25/05/2011 11:31 am
My clothes are getting rather loose. Much more and I'll be cinching in too much waistband, and some of my trousers already look too big with a bit of slack fabric at the front.
Posted : 25/05/2011 11:37 am
i'm going to costco to buy bumper packs of awesome for you all, well done guys 🙂
Posted : 25/05/2011 11:57 am
 Solo
[i]I've had to buy some new jeans and shorts at the weekend.. Now a 30 waist (which i haven't been since i was 18!)
Feels good
[/i]
Years ago, then GF was making a skirt for her mum. It measured more around the waist that it did in drop.
Since then its made me think that I really mustn't let the waist measurement exceed inside leg length.
I've never claimed to be clever or sane.
Edit:
[i]i'm going to costco to buy bumper packs of awesome for you all[/i]
Thanks, but I'm all stocked up here. TSY and MolGrips can divi my share up between them.
Posted : 25/05/2011 12:11 pm
Now getting the hang of these flatbreads - just required a bit of experimenting to get the consistency right.
Just had a couple infused with dry-fried cumin/carroway and then wrapped around leftover roast beef, horseradish, humus and rocket. Proper nom noms.
Posted : 25/05/2011 12:16 pm
 Solo
[i]Now getting the hang of these flatbreads - just required a bit of experimenting to get the consistency right.[/i]
Yeah, I've gone to 130ml water to 100g flour. Was too thick before and was producing iflatbread biscuits.
Can't really wrap mine around much though as they split and break.
Got to try adding stuff to the mixture though.
Posted : 25/05/2011 12:20 pm
Philly, pick up a pack of modesty while you're there. 😉
Posted : 25/05/2011 12:22 pm
... and a tube of iMmodesty. Thnx x
Posted : 25/05/2011 12:24 pm
Doing exactly the same here 🙂
Recipes kept saying 110ml or so but like you say, they kept coming out like cardboard biscuits.
Cooking tip: tiny bit of olive oil in pan (e.g. omelette pan), get up to medium heat, pour in mixture, lid on for 1-2 mins, turn over and replace lid for 1 min or so. Job done.
And it seems to work better if you let the mixture settle for 10 mins after making it ... and stir it each time before adding to pan.
Adding herbs and spices makes a big difference too.
Posted : 25/05/2011 12:25 pm
 Solo
[i]Adding herbs and spices makes a big difference too[/i]
Yeah, I reckon so. I am going to try this on the WE.
Would it be bakeable ?. iGram flour scones ????
Posted : 25/05/2011 12:30 pm
The missus used gram flour to make yorkshire puddings last night 🙂 They smelt like prawn crackers but looked like fluffy rock cakes! Not an issue with a good bit of gravy (gram flour to thicken) on top 🙂
Posted : 25/05/2011 12:35 pm
I know you'll just tell me to search the forum, but what kind of flour are you using the make these flatbreads?
Posted : 25/05/2011 12:37 pm
Gram flour. Not available in Germany.
Posted : 25/05/2011 12:39 pm
what's it made from (please don't let the answer be Gram) and can I get it in Denmark (or has it been banned with the marmite?)?
OK - got it with google. Chick peas
Posted : 25/05/2011 12:40 pm
 Solo
Gram flour is made of Chickpeas. Available in Tesco and Sainsbury's, ime.
Molgrips. Don't go on about Germany. I wrote you could have some gram flour if you want to sort it.
Edit:
Denmark ?, right. Well I've no idea on availability there. Good luck.
Posted : 25/05/2011 12:42 pm
 Solo
I've just BBC'd for scones. Massive iDiet FAIL.
*sticks bottom lip out*
Posted : 25/05/2011 12:46 pm
Thanks Solo, I might take you up on that.
What's BBC when used as a verb?
Just had a snickers too btw 🙁
It's wobble Wednesday!
Posted : 25/05/2011 1:09 pm
C'mon soldiers! MTFU....either go hard or go home!
etc etc
In other news.....i'm getting closer to my own current personal goal of cracking 20 miles at 20mph....
[url= http://i.imgur.com/oHKdt.pn g" target="_blank">http://i.imgur.com/oHKdt.pn g"/> [/img][/url]
Posted : 25/05/2011 1:23 pm
 Solo
Tuna sala for lunch, chickpeas and bacon for breaky.
Lentils, cod, bacon, with chilli spices for dindins.
I iz stil good boy since Saturday.
8)
Grips.
[b]B[/b]riish [b]B[/b]roadcasting [b]C[/b]orporation innit
Anyone tried a egg in with their gram flour ?
Posted : 25/05/2011 1:29 pm
Nice one Jamie. Is that 493 ft of gain in that table?
I've done the trip to work in less than an hour, it's 20 miles the long way, but it's about 30m net downhill I think.
Posted : 25/05/2011 1:40 pm
I think so....click it for biggererness.
Posted : 25/05/2011 1:43 pm
I meant ft rather than m.
Posted : 25/05/2011 1:49 pm
 Solo
Jamie.
You is a racing snake. Much faster than me on the bike.
I do not run.
Posted : 25/05/2011 1:51 pm
I reckon I could do that.... What's the route?
Posted : 25/05/2011 1:52 pm
Jamie.
I do not run.
Not by a long stretch. I am confident Molgrips, TSY, DGOAB, Mr Taylforth, Druidh and probably everyone else on the forum is faster than me.
I must admit, it's good to be back running again. Just taking it nice and slow at the moment....well apart from the odd blip were I get carried away and inadvertently do a 6min/mile.
Posted : 25/05/2011 1:57 pm
NEWSFLASH -
I managed my inward 20 mile commute in 56m 50 secs!
I'm really chuffed with that.
*is really ******* chuffed*
Now for sub 50 min 😯
Posted : 25/05/2011 2:03 pm
I dunno, Jamie.. those are fairly good stats up there...
If I attempted a 6 minute mile I'd need carrying away half way through!
Yeti - good.. route please?
Posted : 25/05/2011 2:04 pm
Only riding a while and he's already approaching 20mph averages. Awesomeness.
My buddy and I averaged 18 on the Étape. Was quite pleased though a few fellow competitors were nearly as cruel as you lot. Few s****s about my saddle not being visible and see through shorts. 🙁
That is impressive TSY - well done! I used to do 17.5 miles in around an hour and be fairly chuffed. Was on an MTB with slicks, but not much in that.
Posted : 25/05/2011 2:05 pm
There is, I reckon.
How can I show you the route?
I don't have any GPS or owt.
Posted : 25/05/2011 2:08 pm
Just tell me where you went, roughly. I bet it was one of those nice TT friendly Thames Valley flat routes...
Yeah, it's pretty flat... net climb on the way in though.
Witney/Curbridge/Ducklington/Kingston Bagpuize/East Hanney/Steventon/Milton (Park).
Door to Door just over 20 miles so I gave myself a bit of a warm up first.
If anyone wants me off the forum I'll be the bloke riding home in pink lycra 🙂
Posted : 25/05/2011 2:19 pm
It is what it is, nothing chosen to help....
....here is the route with exact start/finish points chopped off.
http://www.gmap-pedometer.com/?r=4530858
The Southern Yeti:
You really should invest....best thing I ever bought for my running/riding/hiking etc. Especially routing my rides. Does not have to cost the earth, as a 305 would be good enough and they are about £100 on Amazon.
Posted : 25/05/2011 2:20 pm
Jamie not bad with what looks like suburban riding in it...
Yeti nice.. seems you take a slightly longer route than necessary?
Posted : 25/05/2011 2:25 pm
The Southern Yeti - Member
NEWSFLASH -
Congrats [s]you thunder stealing bastard[/s] buddy!
Indeed. Several sets of traffic lights (got lucky on these today), roundabouts and a busy A-road to cross.
Posted : 25/05/2011 2:26 pm
Yep. It's all about doing 20 miles 🙂
And a bit about riding on quieter roads... you'd be insane to ride along the A34.
Sorry Jamie. I did jump a set of lights on a bridge over the Thames to keep my speed up!
Posted : 25/05/2011 2:27 pm
*doesn't mention still being in pain from cardio marathon on Monday*
*didn't mention being in pain from playing 90 mins of badminton last night*
My cycle shorts came from Lidl, so I know your pain.
...well not the saddle being visible part, but then we know you're lying about that bit.
Posted : 25/05/2011 2:32 pm
Page 27 / 34
