How's this gym...
[Closed] How's this gym workout for weight loss?
I've read that 10-12 reps per set is for hypertrophy, 5 for strength. I don't want to be 'bigger'.
yes, hence my disclaimer that i hadnt read your goals 🙂 footflaps ^^^ is correct.
as for the not using straps as it would mask grip weakness, again that depends on your goal. if its to develop grip strength then id agree. but if performing the DL is because its a good compound exercise and you want to strengthen core/back/legs etc all at the same time, then i dont agree as you would be holding back potential in those areas just cos your grip isnt strong enough.
Posted : 06/07/2017 11:42 am
Stall bar leg raises
That looks like fun, might be an alternative if I don't have access to weights.
I'm of the opinion that since I am climbing steep hills on the MTB that replaces or improves on doing lots of reps of lighter weight in the gym. So I use the gym for strength. DLs seem to give my cycling a bit of pop, purely subjectively.
Posted : 06/07/2017 11:53 am
For Max strength 1-5
For Max hypertrophy 8-12
Yeah, kinda. No harm in growing some GO muscles rather than SHOW muscles.
1-3 Reps = CNS adaptation
4-7 = Myofibrillar Hypertrophy (GO)
8-12 = Sarcoplasmic Hypertrophy (SHOW)
I too have had my best results on big lifts with 3-4 warm up sets then 5x5 with linear progression.
When linear progression stalls (for me it was at 2xBW for Deadlift and 1.5xBW for Squat) then it's time to get a bit cleverer with periodisation.
This explains it very well indeed.
may be teaching granny to suck eggs but make sure you breathe correctly too, exhale on the grunt part of the lift.
Better off maintaining thoracic pressure by holding a nice big breath through out the movement rather than losing that pressure and support of your thorax at precisely the moment you will need it the most.
With regards to using straps, I would avoid them if at all possible.
I use double overhand until I get to about 130kg on the DL then switch to mixed grip.
You're using chalk right?
My elbows were a bit jacked up I found lots of forearm stretching, lacrosse ball massage and ceasing (for a couple of months) exercises that isolated the elbow joint (curls, pressdowns) sorted it. The use of wrist wraps on HEAVY pressing movements seems to have prevented a re-occurrence.
Posted : 06/07/2017 12:54 pm
Ok fair enough. I've never felt myself in a position to put that many hours in - at least, not since I've had the motivation to even think about it.
And this is the issue though. UNfortunately no one is going to get near the front of any type of athletic race unless you can commit many hours.
I have given up on trying to get fit to do bike racing. You are up against people who can spend many hours out riding, which unfortunately I just do not have.
You could try running? It still takes lots of commitment but I reckon its a least a 2:1 maybe 3:1 ratio of time v reward compared to cycling.
Posted : 06/07/2017 1:17 pm
No, I've never used chalk. I struggle keeping my fingers closed, rather than the bar slipping. Do you find chalk helps?
Posted : 06/07/2017 1:35 pm
chalk definitely helps. i use liquid chalk, not as messy/dusty 🙂
Posted : 06/07/2017 1:40 pm
I'll be happy to plateau there. I have no desire to be as good as I could be in the gym - bike is priority.
Chalk - good idea.. Probably have some left over from climbing 🙂
I do yes - I hate it, but I do it. As said earlier in the thread, squatting seems to have caused some kind of muscle imbalance that hurts my ITBS. However I rollered the crap out of it the other day which helped a lot.
You're right. This is about getting as good as I can given the hours I have available.
Posted : 06/07/2017 1:45 pm
Chalk helps massively. The bar doesn't slip so much as it rolls, the chalk gives more friction at the heel of the hand stopping the rotation.
Posted : 06/07/2017 1:46 pm
Hi, long time listener first time caller.... this seams like a good place to ask questions about weights work outs advice.
So i started a lunchtime (30 mins) gym work out 10 weeks ago with the aim to lose a few kg, which I've now done via cardio and watching what i eat.
now I've thrown in a few leg exercises that i got from this tread, step up to a box (and some time jump up) and wights lunges. Surprised my self and I've enjoyed this, so what next ??
Bit of back ground
i only have 30 mins * 4 days a week. Being doing 20-25 reps (3 ish sets) as that seamed more appropriate to help with cycling or is that completely wrong ?
Thinking of 1 day each on legs, back and front, then last day on legs again.
Any recommendation for fun back and front exersies?
I like the look of footflap's gymnasticbodies is there a free source for amateur? I will try the "Stall bar leg raises" tomorrow but it looks a bit advanced for a amateur!!
thanks for any help.
Reddit has a recommended routine, with good support via their forum. Try that...
[url= https://www.reddit.com/r/bodyweightfitness/ ]
Bodyweight fitness forum[/url]
[url= https://www.reddit.com/r/bodyweightfitness/wiki/kb/recommended_routine ]
Recommended Routine[/url]
They encourage people to ask Qs, post videos for form checks etc.
A basic all body strength routine should have at least four elements:
- Push
- Pull
- Hinge
- Squat
and the maybe two more
- Loaded carry
- Lunge
If you have a free weight exercise which covers each of the 4-6 bases, you're covering most of the key areas.
Eg Press ups, Ring rows, Deadlift, Back squat, dumbbell farmers walk and barbell lunge would do for starters.
As for reps, if you want to get bigger sets of 8-12, if you just want a good strength base, 5x5 is a very popular choice.
Posted : 06/07/2017 2:03 pm
Cheers footflap i was hoping you would reply 🙂 i'll take a look tonight.
Posted : 06/07/2017 2:14 pm
@Molgrips I used to train powerlifting pretty seriously (until I broke my elbow on the bike a few years back and I still keep doing the compound moves but now only once a week) but grip on the dead lift used to let me down after a while, usually when the weight got over 170kg.
The mixed grip is key, but use a hook grip (so both palms the same way) for the lighter weights, then shift to a mixed grip (so palms in opposite directions) when you get heavier. If you aren't looking to compete at lifting, then if your grip fails just use straps for the heavier lifts. However, persist using hook then mixed grip as you work up and your grip will get better. Also don't mix your mixed grip, one way will feel more natural so stick with that one. I got taught by a "proper" powerlifter to grip the bar really hard whatever exercise you are doing and think about the grip, even if you are just warming up. That really works for me in helping shift more weight in all exercises.
Don't use the Smith machine for bench, squat or any compound lifts. As mentioned before you can't use the smaller assistance muscles and it's just an injury waiting to happen.
Posted : 06/07/2017 2:15 pm
hanging knee raises are a good intro/ warm up/ preogression exercise.
Posted : 06/07/2017 2:24 pm
Gymnastic Bodies leg lift progression ([url= https://www.gymnasticbodies.com/an-introduction-to-the-manna/ ]from Mana[/url]):
1. Tuck-up 5x15reps
2. Straddle Up 5x15r
3. V-Ups 5x15
4. 1/2 tuck hanging leg lift 5x5
5. 1/2 hanging leg lift 5x5
6. Negative hanging leg lift 5x5x10secs
7. Hanging leg lift 5x5
8. Undergrip hanging leg lift 5x5
Google each exercise...
NB The list goes on for a long time until you get to
25. Mana
I'm on step 6....
Posted : 06/07/2017 2:34 pm
If you pass out shortly after lifting and find yourself lying face first in a pile of weights - that was probably close to 1RM as well...
Yeah, hit my limit at present with 147.5kg. Just can't get past it - three workouts and even adding 1kg is too much, though I suspect it's psychological. Could be the recent calorie deficit, too - never as good as a surplus but I wanna see a bit of what I've worked hard to achieve.
Supple Leopard is good so far - just finished the intro and he mentions my favourite book of old - the Go Rin No Sho! Very influential book in my youth. The rest of what he's written so far seems to confirm what I've been working for over some years now but it's good to confirm you're doing it right sometimes. I'm sure there's a lot to learn from it, too.
Deadlift grip tips from T-Nation...
https://www.t-nation.com/training/tip-dont-use-a-mixed-grip-when-deadlifting
I can't do the mixed grip due to an old injury in the left bicep and for some reason can't supinate my right hand without issues with my body twisting. Which is quite weird...
Posted : 06/07/2017 3:37 pm
molgrips: are you losing weight as you set out to?
Posted : 06/07/2017 3:42 pm
When lifting weights surely the appropriate term should be losing fat...
[i]/pedant[/i]
Posted : 06/07/2017 3:44 pm
I thought that may be a link to the hook grip and was right. Yes some swear by it but for me it felt like it was pulling my thumb out of its socket. Didn't like it. YMMV 🙂
Posted : 06/07/2017 3:45 pm
Yes, but thanks to a somewhat infamous (on STW) diet plan rather than the lifting 🙂 The lifting may be helping me maintain strength and muscle whilst calorie restricting. Also I think that a lifting session helps build strength but doesn't take much out of me in overall calorie terms, which means I'm not getting ravenous and hence the diet is going much better.
Trying to do high intensity workouts on the bike just drives my appetite, so I think this is working well.
I do think I have more muscle and less fat than I had when I last weighed this much though.
Posted : 06/07/2017 3:46 pm
I haven't had call to use anything other than the standard grip so far mostly because it's not the my grip that's making me fail. I have experimented with the mixed grip but like I wrote, I can't risk it with higher weight. Chalk is must, though. I use the liquid stuff, too - much cleaner.
Posted : 06/07/2017 3:51 pm
I only use hook grip for Snatch (up to BW) and that hurts enough! Wouldn't want to try 2xBW, think my thumb would explode....
Posted : 06/07/2017 3:53 pm
Actually, Molgrips, the reason I bumped this thread earlier was to ask if the weights workout was adding anything to your cycling but failed to do so other than in a roundabout fashion by telling you of my own results in that area.
So what do you reckon - given you anything extra or just not translatable to the bike for you...?
Posted : 06/07/2017 11:19 pm
Sorry Teasel - didn't see this post. Answer - hard to tell. I've posted good times on my local test segments and my form is overall prety good lately, but that's because I'm also doing more longer rides than recently. So too difficult to tell really, but maybe. I feel good on the bike and I have pop and endurance despite the diet.
Anyway. So I've been dieting quite firmly and I've lost 3kg as a result, which is good. I took a break from Stronglifts and didn't lift for a couple of weeks then went back to do deadlifting as I said. This wasn't too bad, but the diet must be starting to bite. I went for a run night before last which was a nightmare, no energy at all. And without eating much carbs I'm not recovering quickly.
I've come to the conclusion that the Stronglifts guy is right, deadlifting 5x5 is too hard work to do much of, so I thought I'd try going back to the prescribed workout. My scheduled weight was 90kg and I totally failed cos my legs were still wasted after the terrible run. Just about managed 82.5 which was what you saw me do easily in the video.
So the question is, can one lift and gain strength whilst eating a low carb diet? I've read that lifting helps reduce muscle loss from a calorie deficient diet, but would I be better off doing something other than 5x5 whilst calorie deficient?
Posted : 13/07/2017 9:31 am
You're not calorie deficient Molly, you have a shit tonne of fat.
Posted : 13/07/2017 9:50 am
You know what I meant.
Posted : 13/07/2017 9:55 am
The calorie deficit would have a bigger impact on endurance, no?
I think you just had an off day and your over analysing it.
Don't be tempted to revert back to recovery cans of coke.
Posted : 13/07/2017 10:14 am
Don't think so. On endurance rides I can burn fat, but the lifting is using up ATP and I think you need carbs to resynthesise ATP no?
Well high GI post-exercise carbs for recovery has a pretty solid scientific basis I think. If you use up muscle glycogen stores, then you need to replace them and psot workout is the best time to do it.
Posted : 13/07/2017 10:18 am
FWIW - Whilst leaning out I have found that whilst I can still gain strength (on 3 rep sets) it's at a slower rate. This is probably down to continued CNS adaptation but with a slower rate of myofibril hypertrophy.
Posted : 13/07/2017 10:24 am
Whilst leaning out
Wondered what you meant for a minute 🙂 How are you approaching this?
Posted : 13/07/2017 10:27 am
So you still have carbs after a ride? Even if you don't I'm almost certain you've not restricted carbs so much that you don't have enough within your liver and muscles at any one point to get you through a workout.
Edit: I was about to give you some 'tough love'
Posted : 13/07/2017 10:40 am
I am by no means an expert so take this with a pinch... I'm trying to lose a tad of body fat just to see what my body looks like with around 15%. I've cut down to less than 100g of carbs but don't really count them. I focus more on eating around 1.75g of protein and 0.9g of fat per kilo of body weight. I've cut back the weight on the bar by 5% and dropped to 3x5 on everything bar DLs which are and always have been 1x5 (after warm up sets, of course) so basically I'm attempting to keep bar intensity the same to avoid muscle loss. To my surprise I sneaked an extra kilo on the presses and row without undue problem so I reckon it's possible to keep adding. This guy explains it much better than I can...
http://www.bodyrecomposition.com/training/weight-training-for-fat-loss-part-1.html
My results are a loss of that band of fat around the middle - an inch in 2 weeks. A loss of weight by 2 kilos which is noticeable in the belt hole being one smaller and the trousers fitting looser on the thighs and arse. I haven't noticed any energy deficit when doing 10 minute hill sprints twice a week so carbs must be just enough. The deficit is only around 300kcal below maintenance but sometimes I like to see how low I can go before I almost pass out. Mind over matter kind of approach - probably foolish.
These calculators are useful for a general type of figure to aim for...
http://www.scientificpsychic.com/fitness/diet.html
http://www.scientificpsychic.com/health/cron1.html
Below the calc on the second link is an interesting bit on a woman eating only 1000 calories.
Don't ask me about the rest of the site as I haven't explored but it's got a rather weird name that kinda puts me off of doing so.
Just to add - I've been eating mostly whole food - chicken, broccoli, cauliflower, cheese, greek yogurt, blueberries etc. but have also consumed a fair bit of pizza (a particular brand and type fits my dietary requirements so is all good now and again) as well as having the odd ice cream and micro bottle or three of Peroni. The fat is still falling away - don't know why, it just is. I guess moderation is key and not depriving yourself as that's wholly unsustainable in reality.
Posted : 13/07/2017 10:52 am
Yeah, it's not clear. My run was an utter debacle. There may be other reasons for it, but running is always really hard when dieting.
I'm not restricting carbohydrate to an extreme level, but the question is how much glycogen stores am I using up by doing the riding/running/lifting? I'm pretty sure my stores are not full.
Yes - there is a sweet spot. Too much and you don't lose weight, too little and you can't work out.
Posted : 13/07/2017 11:24 am
I was thinking more about the psychological aspect i.e. if you like to have a beer or cake or whatever then have it.
Admittedly it pays to adjust ones taste to foods that are beneficial like good cuts of meat, veg, pulses etc. but I reckon there's a lot to be said for the feel good factor of eating a little of what you like even if it's considered junk food or on the 'bad list' because it's alcohol and it's empty calories or something. I also think the body is quite happy as long as it's getting its basic minimum of fat and protein and will accept carbs from any source as long as you don't over do it or break any other target you might be aiming for.
Posted : 13/07/2017 12:21 pm
Yes. I had a salad for lunch, but then afterwards I had two custard cremes. Don't tell TheSouthernYeti though he'll laugh at me then pity me 🙂
Posted : 13/07/2017 3:06 pm
Posted : 13/07/2017 4:53 pm
Losing about a kilo a week at the moment. I think most of it is fat from the thighs and belly and a bit off the arse but unsure as to how much muscle mass is disappearing*. I have a feeling that fasted workouts weren't working for me, particularly as I sometimes don't lift until 2pm. Was trying the 8 hour feed window before with just a few hundred calories more but fat loss was slow. The change has been with eating when I feel hungry but only consuming enough to get in about 30 - 40 grams of protein - I reckon it's keeping my metabolism going so burning all the time.
A kilo a week - a bit too much, isn't it?
Sod's Law'll say I have something nasty cooking away out of view again only I won't spot it this time because of the intentional fat losing experiment.
*Intensity (weight on bar) has been kept as close as possible to the weight when I was bulking/building strength to try to avoid significant loss.
Posted : 17/07/2017 12:41 pm
I lost that when I was iDieting the first time around, and it stayed off - took some pretty persistent metabolic abuse to put even half of it back on (we had a baby...)
Any idea what your fat percentage is? What height/weight?
I hovered in the 86s all last week, didn't lose, but have already lost a little this week so hopefully I can refocus. Planning to do lots of gentle biking since I am home, and a couple of gym sessions.
Must make sure I eat enough carbs, but not too many. Two years ago I got stuck at 91 whilst eating not much and doing shorter high intensity rides (due to work). At least this time I seem to be stuck 5kg lighter 🙂
I should start measuring my gut. Cycling jerseys are starting to get loose around the waist.
Posted : 17/07/2017 1:39 pm
Body fat is around 22%. The calculator that I linked to earlier in the thread suggests I have around 60kg of lean mass.
I'm now 77kg at 173cm
Main thing is I'm happy and strong and heading towards my goal with relative ease. That's always a good thing. I would never have thought I'd be like this about 3 years ago at 46 - I was aching and groaning on getting to my feet thinking it was old age kicking in. How wrong I was...
Edit : And it turns out I can still have the odd pizza and beer or cake or whatever as long as it's taken into consideration. IIFYM... 🙂
Posted : 17/07/2017 3:10 pm
a kilo a week is fine.
Posted : 17/07/2017 6:48 pm
Inexplicably managed to lose two kgs on holiday. I only did two rides and one run, and I ate shitloads of biscuits.
I was 84kg when I got home after an entire day of eating shite on the motorways. That's a weight I only dipped below twice in the last 15 years or so!
Posted : 15/08/2017 2:06 pm
Page 7 / 7
