How tight is 150 in...
[Closed] How tight is 150 in.lb
[#1834396]
When using a normal 15cm long ish 5mm allen key??
Posted : 26/07/2010 9:22 pm
150 in lb = 1lb at 150"
= 20 lb ish at 6"
Sounds bloody tight to me
Posted : 26/07/2010 9:26 pm
'kin tight. What's it on?
Posted : 26/07/2010 9:28 pm
its about 17 Nm according to this [url= http://www.thetoolhut.com/Torque-Conversion-Newton-Meters-Inch-Pounds.html ]conversion chart[/url]
Posted : 26/07/2010 9:30 pm
Approximately the same as 9.183 × 10^-47 light year solar masses, if this helps you get a more practical mental image of the torque.
Posted : 26/07/2010 10:13 pm
pivot bearings on intense 5.5
Posted : 26/07/2010 10:17 pm
Bought the same as 11 bags of sugar on the end of you 6'' allen key
Posted : 26/07/2010 11:30 pm
150 in lb = about 12.5 ft lb = not very tight at all. a good shove on a allan key depending upon the size of it
6 bags of suger on the end of the allan key ish
Posted : 26/07/2010 11:34 pm
