I rode lands end to John O'groats last week over 7 days in aid of charity & since I've been back I have had pins & needles in my left foot (permanently) & lower back (when bending)
Anybody experienced this?
Not sure whether I need to see a doctor, a physio or whether it should go away after my body has recovered. It's not painful at all just slightly annoying!
I'm used to 20 miles a day but amazing how you start falling apart when doing 130 a day!
cheers
Martin
It's a nerve problem go see doc or physio (either or) about it.
Docs first - sounds like a back issue causing nerve compression - quite probably just spasm and nothing serious but needs to be checked out incase
TJ. You can't possible make that diagnosis on the information given. Behave yourself.
Surrounded By Zulus - Member
___________________________________________________________
TandemJeremy - Member
Both replies sound very similar to me.
There are a few differences though.
cheers guys - docs here I come thought it best to get checked out
Surrounded By Zulus
Yes - the difference is you say "it is"
I say "sounds like .......... quite probably"
No diagnosis from me. I say to go to a docs, what the issue likely is - nerve compression from a back injury and the most likely cause as a reassurance as most likely it is not serious and then I reinforce go and get it checked professionally.
Well done in your JOGLE!
Hopefully you'll get it sorted soon.
