Heavy duty rubber b...
[Closed] Heavy duty rubber bands - where from?
[#11415003]
Looking to get some extra black rubber bands, the "heavy duty" ones, that come with cheaper bike computers, cadence sensors etc.
Had a look on ebay but they don't seem to have them.
Any suggestions?
Posted : 06/10/2020 12:28 pm
do you mean o-rings?
They are generally measured by inner diameter & thickness, so you might need to do some measuring up of what you need.
ebay:
ebay o-rings
or it might be easier to search a 'proper' shop:
Simply Bearings O-rings
Posted : 06/10/2020 12:33 pm
Many thanks!
O rings might be the best solution.
Posted : 06/10/2020 12:38 pm
I cut a slice through an old inner tube, whatever width you need. You can alter the diameter a bit by cutting diagonally.
Posted : 06/10/2020 1:07 pm
@gobuchul If its the O-rings as used for the Garmin mount you're after, I may have some I can pop in the post.
Post up on here if they are and I'll have a look tonight
Carlos
Posted : 06/10/2020 2:26 pm
@carlos - thanks for the kind offer. But it's for something a little bigger.
Might try that inner tube idea, I have a job lot of 26" tubes that are sitting in a box still.
Posted : 06/10/2020 2:39 pm
You want to search for silicone o-rings, not rubber o-rings to find the right thing.
Posted : 06/10/2020 8:01 pm
