Heating oil consump...
[Closed] Heating oil consumption question
[#5272131]
If you have oil fired central heating can you please tell me:
what temp your boiler is set at
how many radiators you have
how long on per day
how many liters used per month
cheers - a very ****ed off rob who is currently using nigh on 200L per month some how!
Posted : 23/06/2013 5:44 pm
You may well have a leak, somwhere underground,trace the route of the supply pipe from the boiler tothe tank, look for dark patches of ground and or a smell.
Posted : 23/06/2013 5:46 pm
Leak or its been pinched. Are you checking the tank regularly for sudden drops?
Posted : 23/06/2013 5:48 pm
9 rads
Boiler temp - 68
4-5 hours at weekends, 1-3 hours weekdays.
Approx 600 litres a year
Ps. The log burner helps
A mate used to use around 2000 litres a year, but that was in a huge 5 bedroom bungalow and there heating was at 25 degrees 24/7 365 days a year. He has moved now.
Posted : 23/06/2013 5:49 pm
I have a varible temp timer
I have it set to maintain 14 all the time in winter - rarely comes on and 19 for 2 hour in the morning through winter for before we get up.
Right now heatings off
8 rads - 3bed house
Combi
We used 500 litres a year in all the oil fired houses we have had
We used the stoves and eco fan +open coal fire in office to heat the house when we are in though.
Could have paid a fortune to get gas installed last year but just stayed oil as its not stupid expensive amd lets me monitor costs as oppose to getting stung + easy to repair my self 🙂
Posted : 23/06/2013 5:50 pm
If it is being nicked check for obvious tampering with valves or connections also look around tank for a small nut or bolt sticking out, someone drills a hole and inserts nut and bolt, and then late at night or when quiet removes bolt slightly and oil runs out in a container, then nut done up again stopping flow. or just by syphoning fuel from top lid or vent pipe.
Posted : 23/06/2013 5:57 pm
Looks like the boiler uses 2-2.5L per hour, its on on average for 4hrs per day
Rayburn uses 2.5L per day so total usage of 12.5L per day!!
12.5 x £0.65 = £7.80 per ****ing day!
Posted : 23/06/2013 6:17 pm
Oooooft rayburns - look nice but holy jebus they cost.
Posted : 23/06/2013 6:25 pm
 br
Ok, firstly you say boiler and then tell us you've a boiler and range...
Are you sure that the Rayburn only uses 2.5l per day, as in winter our Redfyre consumes about 10-12l per day - dropping to 3-4l in summer.
In balance we've only the Redfyre and a wood burner covering a large open plan ex-mill.
Posted : 23/06/2013 6:45 pm
