Assume you had an vented system before ?
telford does a vented cylinder with a heat pump high efficiency coil – im sure others do also
All a bit beyond my knowledgebase mate! I've had an independent plumber quote me over 7grand (including grant!) and now Octopus saying they can't do it. Not sure where to go next tbh. Will leave it a few months, see if Octopus come up with another option (or the boiler dies)... see where I am then.
I don't think you need a specific tank size for the system to work. They are making an assumption of how much water you get through, and since you are heating it up to a lower temp you need to store more hot water. You will only be using water at 40C, but when the hot tank is at 65 you dilute it with cold. When the hot tank is at 50C you dilute it with less cold water so you need more hot.
You do need a longer or finer heat exchanger in the HW tank though so assuming you can find a smaller tank with a suitable heat exchanger you could persuade them to fit a smaller tank that will fit in your cupboard, and sign a waiver to say that you won't complain about there not being enough hot?
Well, they asked about occupancy - ie. just me at the moment - but were talking about if I came to sell up and potentially a family of 4 could move in... We didn't discuss that further... but I don't know if they only looked at 4 person occupancy or, smaller capacity (I don't care if a new tenant runs out of water!). No idea, wasn't given any options, so I guess I'll see if the survey comes back with details.
I came to sell up and potentially a family of 4 could move in…
That thought entered my head about the tank size and house size. It is good to know that some thought is being applied by the installers even if it isn't by the current owners!
My combi boiler has developed a fault and I'm reluctant to get it fixed straight away. I'm going to see how I manage with a gas hob/electric kettle for water heating, no gas central heating or hot water for showers. So I've joined a gym (shower) and I'll equip myself for a shower at work. A slight routine change will be needed but I might be able to make inquiries into electric heating and water but not using a heat pump?
Don't expect much back other than the survey fee. They would not give me the details or calculations once our house had been deemed unsuitable.
Well, that’s interesting – full survey done – and in the end they haven’t got a tank that would fit in my available storage (the old airing cupboard), so a heat pump is a no go currently.
I could be talking rubbish, but I think you could fit an air to air heat pump, which circulates hot (or cold) air around your house, so you'd keep your existing hot water tank, which would work from an immersion heater (maybe via panels and battery).
You'd need to fit alot of ducts around the house, but it would be air conditioned in the summer.
Probably just not attractive to their business model. I'm certain it could be done, but you'd have to find someone willing to do all the design and remediation work and it wouldn't be cheap.
What size space have you got for the cylinder, and have you got a loft space? Horizontal ones are available, granted not as optimal as vertical ones. There are also vented versions that can be used as others have said, slimline too and a few square options that also may work as they also often have everything you need inside them so less space required for pipework etc.
Octopus just pick the low hanging fruit, because they claim install is only £XXXX anything that is outside of that boundary or the products they want to use is a no.
In terms of the hot water tank, it comes down to whether the installers (or the equipment suppliers) are willing to warranty the overall system. I had a good sized 250litre tank that enough coil surface area to "do the job" and the tank was more than fine fir our actual usage. The overall system supplier (Midea) wouldn't warranty the overall system without installing a 300litre tank based on their assumption of out usage cycle as it could result in the system "not performing" - either the heat pump cycling too often or future users having a higher hot water demand.
Most installers will want a hot water tank and another buffer tank in the system yo reduce the number of starts of the heat pump as it gives the system the opportunity to smooth out the stop starts by heating water that you don't strictly need it to.
All a bit too Conservative in my view, but they are the ones backing up the performance/warranty, do you just have to go with the flow.
Set the heat pump to run at reduced output on hot water..... problem solved
The hot water tank was an issue for me as the existing one is in an airing cupboard in the eaves and couldn't cope with the bigger tank without extending into the bedroom.
It got relocated to the garage and I'm planning to box it in with some studwork and insulated plasterboard, but tanks are so well insulated it's not a big deal.
Longer pipe run but that's about it. Needed to replace the shower with one that doesn't have a flow restrictor in it.
Currently trying the low and slow method with our gas boiler, i.e. heating 'on' essentially all the time. All of the main rooms have Smart TRVs which are set to 19C in the day then 18C upstairs or 17C downstairs at night. Flow temp is set to 'e', not sure what that translates to on a Logic Heat 18. House is definitely warm enough (unless it's windy, but that can be fixed). I can see that the heating comes on briefly at times overnight, but this has all but eliminated the large period of constant running in the morning to get the house back up from cooling overnight.
I'm wondering about dropping the flow temp lower, but this will also drop our hot water temp. This lead me to wondering about hot water safety, doesn't your hot water not need to be hot enough to kill any nasties in the tank? If you have a heat pump with a flow temp of 50C, do you risk hot water that's unsafe?
I’m wondering about dropping the flow temp lower, but this will also drop our hot water temp. This lead me to wondering about hot water safety, doesn’t your hot water not need to be hot enough to kill any nasties in the tank?
My boiler has two temperature settings, one for hot water and one for heating
Yes and no:
https://www.heatgeek.com/hot-water-temperature-scalding-and-legionella/
The problem is though that even if you want your hot water heated to 50C you may well need a flow temp of more than that. How much more depends on the size of the heat exchanger in your tank and how well your gas boiler can modulate.
I have an EV electricity tariff, so I can use the immersion heater to heat as much as I like overnight for less than the cost of gas; but if I want a lot of water later in the day I manually turn the gas on and for that I whack the temperature up. Some boilers as above do have two temp settings so you can do this automatically.
Heat pumps run different flow temps for hot water. Modern R290 ones flow temp can get to 70deg and they neatly all can run an anti legionnaire cycle, others use a back up heater.
The number of deaths from legionella from domestic hot water systems is very small possibly non existent.
For info, my HW cylinder, expansion tank, controller and all the gubbins fits in my kitchen cupboard with plenty room to spare which is 800 wide, 600 deep and floor-to-ceiling. The installer originally wanted to use the whole understairs which is a metre by a metre.
