Hard drive dock for...
[Closed] Hard drive dock for Western Digital.
[#8298572]
I've an old Western Digital hard drive with loads of pictures on that I was hoping to retrieve with a docking station, but all the things I've searched for says it can't be done. I found one that seems to say it's possible but it's in Chinglish so not sure.
Any other ways to get the pics? Or is it for the bin? Ta
Posted : 21/01/2017 5:57 pm
Your question lacks the information that would be required to answer it -
how old ?
What interface does it have ?
Write down what it says on the drive lable / Post up a picture of the connectors on the drive and we'll be able to give you an answer.
Posted : 21/01/2017 6:07 pm
Edit: what cranberry says - then we can tell exactly what to buy (probably a Sata caddy)
A simple usb docking caddy (£10-15) will let you mount the drive like you would a usb key. This assumes the drive isn't actually ****ed - even then I have got data off an old hard drive which would not boot.
Posted : 21/01/2017 6:11 pm
[img][url= https://c1.staticflickr.com/1/460/31599002814_bd366fe064_z.jp g" target="_blank">https://c1.staticflickr.com/1/460/31599002814_bd366fe064_z.jp g"/> [/img][/url]
This pic any good?
It's from 2004
Posted : 21/01/2017 6:27 pm
Yup good enough. It's the old IDE connectors (pre Sata).
Will google some ...
Posted : 21/01/2017 6:36 pm
Something like this (I think need to double check 3.5" vs 2.5")
https://www.amazon.co.uk/d/gjr/3-5-IDE-Hard-Drive-Caddy-External-Enclosure/B002K00G0W
Obviously plan A would be to borrow one as it will be a 1-off job. Work IT ? I have a rough amd ready one but it would probably cost as much to post it to you as buy one 😐
Posted : 21/01/2017 6:41 pm
No. Not in IT.
Shirley someone in IT would not ask such a question.
I do know someone but he wouldn't have a clue. 😀
Thanks for taking the trouble of looking for me. I'll have a punt at the caddy you suggested tomorrow.
I've loads of old biking photos which I'd love to get hold of.
I might even post some up on STW.
Thanks again.
Posted : 21/01/2017 7:06 pm
Cheers redthunder.
It says it won't work with Western Digital IDE though.
Mine is a EIDE so... still puzzled.
Posted : 21/01/2017 7:13 pm
I use one of these (not this exact model but there's hundreds of clones, they're all broadly the same).
https://www.amazon.co.uk/IOMAX-SATA-Adapter-Power-Drive/dp/B000R18ZNQ
Posted : 21/01/2017 7:17 pm
Buy the one in Cougar's or Redthunder's link as it does both standards. It will probably sit unused again for many years or if you can be bothered sell it on ebay afterwards.
btw Work IT ? Meant can you ask work IT rather than do you work in
Posted : 21/01/2017 7:22 pm
Can't think why, a standard is a standard.
For the purposes of this exercise, it's the same thing.
Posted : 21/01/2017 7:23 pm
Pretty sure any modern IDE>USB adapter will be compatible with the latest version of the IDE protocol, whatever that is. You may have to set a jumper on the drive to "Master" or, you may not. Start by just plugging it in.
IMHO - buy any adapter from Amazon that has a decent amount of feedback and costs a couple of quid more than the cheapest, preferably not one poasted from China or you'll never get a refund.
If you have a few more quids try this:
https://www.scan.co.uk/products/startech-usb-30-to-sata-or-ide-hard-drive-hdd-adapter-converter-cable
EDIT _ took too long to type, maybe buy the one c00gl3s just suggested.
Posted : 21/01/2017 7:29 pm
Oh, one other consideration with IDE,
Don't connect / disconnect the data connection with the power attached, always remove the power first. IDE is not designed to be hot-swap (unlike SATA). On a regular PC motherboard, unplugging IDE cables live is a fantastic way of blowing up the controller.
Posted : 21/01/2017 7:33 pm
Good point. Cable Select is probably what you want.
If you're feeling cheeky, you could buy it, use it once and then return it for a refund. Not sure as I would, but I don't know how your moral compass is aligned. (-:
Posted : 21/01/2017 7:36 pm
Thanks all anyway. I'll just get one you've suggested. Cheers.
Posted : 21/01/2017 7:59 pm
All my WD drives work in the caddy I mentioned.
Posted : 21/01/2017 8:13 pm
is it really called a 'jezalung' ?
Posted : 21/01/2017 8:49 pm
