Garmin 800 question...
[Closed] Garmin 800 questions
 HB47
Just bought a GArmin 800 with the OS 50,00 map pack. Trying to get to grips with the basics and have a couple of qeustions:
1. Is Basecamp the best software for managing the GArmin on my Laptop.
2. In the devices list there appears two drives , one seems to be the Garmin itself and the other I think is the SD card which the OS Map comes on. How do I check the available space on each - can you store tarcks and routes on either - will they both be displayed as courses on the Garmin
3. Is it best to create routes in the library and then export them to the Garmin drive - or is it better to create them on the Garmin HD directly
4. How do you delete routes off the Garmin drive - if I create a route in the library it seems to be easy - but can't delete them from the Garmin drive - obviously doing something wrong.
Thanks
Posted : 02/04/2011 10:52 pm
