Furniture making. C...
[Closed] Furniture making. Connecting metal rod to timber sheet.
 huws
[#7046616]
I'm trying to finish off a piece of furniture from my university days and I've become stuck on the name of the bit I need to connect the frame to the seat.
It's a little fixing that clamps the 10mm metal rod to a timber seat base.
Something like the drawing below (drawn upside down for clarity/confusion)
[URL= http://i5.photobucket.com/albums/y173/spearmintrennie/99D7A40A-5260-48E4-93DD-95B6F73D4AD7_zps71ukz8hn.jp g" target="_blank">http://i5.photobucket.com/albums/y173/spearmintrennie/99D7A40A-5260-48E4-93DD-95B6F73D4AD7_zps71ukz8hn.jp g"/> [/IMG][/URL]
Thanks
Posted : 06/05/2015 9:14 pm
That sir is a bracket.
Posted : 06/05/2015 9:32 pm
You could use a Stauff clamp (used for pipework) http://www.ebay.co.uk/itm/Stauff-Pipe-Clamp-Bodies-Standard-Series-PP-Sizes-0-25-2-5-/111271075565?pt=LH_DefaultDomain_3&var=&hash=item19e845deed
or look for/make an omega clamp:
or make one like your diagram out of wood?
Posted : 06/05/2015 9:41 pm
 huws
Lesgrandpotato, 18 pages of the Hafle catalogue would suggest it isn't. Can't believe I went through them just in case.
Andyl, thanks. Bit more industrial than I was looking for though. Really after something small, plastic, black and neat. If I was to make one out of wood it would be shocking. My 'making' skills are somewhat lacking.
Posted : 06/05/2015 9:58 pm
Earthing and lightning conductor uses 10mm rod and has clamps to hold them tight to surfaces, but I don't know whether they would have the look you want.
Posted : 06/05/2015 10:11 pm
Staple?
Posted : 06/05/2015 10:54 pm
Something like [url= http://uk.rs-online.com/web/p/cable-clips-clamps/1844609/ ]this[/url] might do the job quite neatly.
Posted : 06/05/2015 11:05 pm
make your own with a strip of metal
Posted : 06/05/2015 11:13 pm
Could you not just bend a strip of metal and drill a couple of holes in it?
hmm not the prettiest... http://www.kiowa.co.uk/1220-P00006279/10mm-C2-Std-PP-Pipe-Clamp-Jaws
Posted : 06/05/2015 11:14 pm
You could use 2 of those things tony linked to on each side - ie 4 per bar. Just have one with the screw on the front and the other on the back and butt them up to each other with 2 per side.
The stauff clamps won't be very big for a 10mm bar and are quite rigid plastic so low give. They are green though.
Should be easy to make an omega shaped metal clamp out of some stainless steel though.
Posted : 06/05/2015 11:15 pm
Rather aptly for the forum, they appear to be called saddle clamps 🙂
Posted : 06/05/2015 11:27 pm
Or to broaden you googling a 'Pipe Saddle'
Posted : 07/05/2015 1:08 am
Or use a 10mm fairlead, obtained from a chandlery
Posted : 07/05/2015 6:15 am
Square block of wood, drill 10mm hole, cut in half = two clamps.
Posted : 07/05/2015 7:57 am
 huws
Slackalice. Thank you, they look perfect. And luckily there is a chandelry just down the road.
Posted : 07/05/2015 10:12 am
