[url= https://c7.staticflickr.com/9/8319/30014032886_a839d5e3ec_c.jp g" target="_blank">https://c7.staticflickr.com/9/8319/30014032886_a839d5e3ec_c.jp g"/> [/img][/url][url= https://flic.kr/p/MJeLiC ]20161001_193037[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
I like that a lot, but is that a gap in your grouting (by the right hand face plate)?
Either have the flats of the bolt heads parallel to the arc tangent or the points lining up with the radius, sheesh man, details!
And the clock's wrong, it's just gone half ten.
Too much time on yer hands man..
Get a job!
allen key headed bolts in black.
Does the speed of time change according to the sprocket chosen? 😆
Good job!
Missing a washer
Yep, needs cap heads instead of bolts
Countersunk Allen head bolts would be even nicer. 😀
Carbon steel bolts? 🙁
Different bolt sizes around the pcd? 🙁 🙁
Bolt heads will be lined up.
Missing washer will be added.
Tile will get grouted.
Thanks for feedback.
Looks like 2 washers on the bolt at the 10 o'clock position
Just one washer there but missing one at 6 o'clock.
I like it. The bolt heads being at odd angles is fine if they're all torqued up the same 😀 Needs more lockwire.
