Driveway finish ins...
[Closed] Driveway finish inspiration please !!
[#6827355]
Hi all.
Need to get the driveway redone on our house as the tarmac is crumbling and starting to dip etc.
I need some inspiration on the various types of finish you can get nowadays.
Father in law has block paving which looked good to start with but now has weeds coming up etc.
Wife likes this new resin stuff but I'm not sure on durability and cost etc
What do you have ??
Posted : 01/02/2015 8:21 pm
We've got the resin stuff. 4 years now and counting and to be honest it does now need a re seal because some moss is starting to form but that may be due to the heacvy tree coverage on our road. Mine is pretty much the same as this picture (my black border is much narrower) but it was done by the same contractor. Can't remember the exact square footage of our drive but it is almost exactly the shape pictured and I can easily get two cars on it side by side. Cost £1750 iirc including the brickwork around the edges.
I'd go for the same again if given the choice
Posted : 01/02/2015 11:00 pm
Had our new drive block paved by the builders who put up our extension 2 years ago. No moss or weeds as yet.
Posted : 01/02/2015 11:11 pm
New tarmac with a nice border always looks good, block paving is a susceptible to "dipping" as you call it as much as tarmac is when the sub-base isn't sound. If it's a small drive where cars pull on and off in similar positions everyday then resin is susceptible to wear. I like patterned concrete but one failed service under your drive and the patch cut out looks shite!
Posted : 02/02/2015 12:08 am
What do you have ??
Crumbling bumpy tarmac!
It's a long and narrow drive and old house so we will probably go for flags with a grass strip down the middle like cart tracks.
Decided to leave it for now and buy another bike!
Posted : 02/02/2015 12:14 am
Block deffinately block
Posted : 02/02/2015 12:31 am
Bregante how is the resin stuff holding up ? Have you got any loose bits ?
Posted : 02/02/2015 11:10 am
Nope. Its all very sound
Posted : 02/02/2015 4:44 pm
Had ours blocked 10 years ago. Gets a power scrub once a year, not had a problem with weeds or dipping, usually has three cars parked across it.
Posted : 02/02/2015 4:56 pm
If security is an issue I'd go for a nice noisy gravel every time.
It's a great deterrent for 'uninvited guests'.
Posted : 02/02/2015 5:14 pm
I've got a noisy gravel drive from when I extended it when the kids lived at home with their cars too. I dug it out nice and deep, whackered diwn proper sub layer and membrane then 6" depth of 20mm gravel....went for 20mm to avoid the gravel stuck in new tyres issues. No puddles, no skating rink in ice, no weeds and a big of added crunching under foot security. Plus, whilst our driveway may not appear as "posh" as all the other block paved ones or crumbling resin ones or splitting pressed concrete ones on the estate, I have had and expect no issues in the near future. 😆
Posted : 02/02/2015 8:16 pm
Something permeable please, all these paved drives are contributing to localised surface water flooding and depriving the trees of water.
Posted : 02/02/2015 8:47 pm
 iolo
pictonroad - Member
POSTED 2 MINUTES AGO # REPORT-POST
Posted : 02/02/2015 8:53 pm
