Conflicting policy/...
[Closed] Conflicting policy/message on energy use
quote]They need far too much water for cooling and to dilute the radiation losses to be sited near major conurbations.
true we have no major conurbations in this country near rivers or the sea do we 😯
In the long run, it's either nuclear fusion (which doesn't work yet), or we go back to an economy based on goats and parsnips
Yes of course no middle ground between those options 🙄
Clearly we have no other alternatives if only we had tides or say a sun or hydro electirc or etc
Posted : 16/07/2009 11:32 am
ahwiles - Member
safe disposal of nuclear waste is easy, just bury it inside a granite mountain.
If its so easy why has no one actually found an acceptable method yet?
we have found a safe disposal method - bury it inside a granite mountain.
The problem is convincing the local population that it's a good idea.
Posted : 16/07/2009 11:39 am
Ahwiles - simply not true. It is not safe to do this. many objections. Firstly some waste is so hot that it needs to be cooled, secondly there are geological faults where the waste could seep thru. It simple is not safe enough to do this and no one worldwide has found an acceptable solution.
Posted : 16/07/2009 11:42 am
don't bring me problems, - bring me solutions!
ok, bury it inside a COLD mountain, and seal up the cracks with a bit of silicon bath sealant.
there, the problem of disposal is now solved. once and for all...
(anyway, did you read all of my first comment? - i don't think Nuclear fission is a long-term solution, i'm with YOU in this discussion, and you're trying to argue with me, are you having a bad day?)
X.
Posted : 16/07/2009 11:47 am
Open question - Assuming nuclear waste can't be safely stored....
What do YOU need electricity for so much that justifies creating nuclear waste?
Posted : 16/07/2009 12:03 pm
Porn 🙂
Posted : 16/07/2009 12:13 pm
It's easy! Firstly, why put dangerous toxic waste in our own back yard when we can export danger, catastrophe and poverty to other countries!? We've been great at this for centuries. Build a load of parabolic sun reflection power stations in the oh so sunny middle east and deserts of the world and then fund a huge super grid to cloudy old England. Employ the locals to polish said mirrors for a pittance and work in atrocious conditions with no water/holidays/human rights whilst we get a load of delicious electricity to enable us to continue our luxurious internet based lifestyles.
In short, yup, we're all doomed.
Posted : 16/07/2009 12:16 pm
 D0NK
You've all made me so energy concious I just switched off the second monitor on my PC
Posted : 16/07/2009 3:01 pm
Seeing as no body picked up on my point earlier I'll make it again. We should be changing our power sources for better reasons than global warming which we, as a planet, have zero chance of getting our act together and preventing (even if we have caused it). Fuel security is going to be much more of a pressing issue in a few years and unless we want to get sucked into even more wars we've got to spend money now on renewables.
No one (apart from those underwater) will give two hoots for global warming when the lights go out and the tanks start to roll.
Posted : 16/07/2009 7:07 pm
mrmo and I did stumpyjon!
Posted : 17/07/2009 12:28 am
Doomed
It's just a question of exactly when.
Sustainable population of Britain is somewhere between 10 and 20 million. 20 years of oil left (at the outside)and at the present time we use 9 calories of energy (oil) to produce 1 calorie of food.
When the oil runs out so does the food. Gone are the days of knowing how to use both manpower and horse(as in the 4 legged variety)power to produce food.
It's going to be pretty grim as it won't happen suddenly. As awareness of our impending plight grows society will breakdown. We're up S**t Creek with no chance of ever getting a paddle.
Posted : 17/07/2009 1:05 am
I think humans are the last species that needs to worry about being doomed.
Posted : 17/07/2009 8:43 am
Page 2 / 2
