Cleaning black moul...
Cleaning black mould spots from wood?
 ben
[#13232985]
Morning all.
Some Teak wood on my boat isn't looking great after a winter outside. I think it's picked up some mould spots, seen on the photo below.
I think the answer is to sand it down as best I can, unless anyone has some other bright ideas?
[url= https://i.postimg.cc/6prPqJ1N/IMG-2612.jp g" target="_blank">https://i.postimg.cc/6prPqJ1N/IMG-2612.jp g"/> [/img][/url]
Posted : 24/04/2024 9:34 am
I get lots of this on the hardwood garden furniture ... normally I oil over the top and it seems to do the job.
IANAWWE
@kayak23 and other types will probably give much better advice.
PS - you probably need to line up all your screw heads there 😉
Posted : 24/04/2024 9:38 am
following. I sanded down and painted over a windowsill the other week and the paint has come off with an impressive pattern of mold under it.
Posted : 24/04/2024 9:50 am
Oxalic acid is, I believe, the answer here. That will remove residual staining after you’ve sanded or scraped the varnish off. I’ve never used it on teak, usually oak, but a quick google suggests oxalic acid is still the right answer for teak. Just avoid getting any on your shiny metal hardware, may tarnish it.
Posted : 24/04/2024 9:55 am
 ben
Cheers All.
I've removed the doors for cleaning Reeksy, so will ensure better alignment of screw heads when I refit 😉
Posted : 24/04/2024 12:33 pm
Try and avoid sanding, or you'll have nothing left in a few years!
Yes, oxalic acid or a proprietary teak cleaner once any varnish has been scraped off. Brings it up lovely!
Posted : 24/04/2024 1:48 pm
Anothe rvote for oxalic acid, we used it to clean tea outdoor furniture after reading that it is the standard for cleaning teak decking on boats.
Posted : 24/04/2024 4:41 pm
 ben
Oxalic acid did indeed do the trick, thanks all. This is after 2 passes with medium strength, might give it one more pass.
[url= https://i.ibb.co/X5GRxsH/2-F32-F96-B-0912-4-A4-A-9-F14-AD060-CE065-F6.jp g" target="_blank">https://i.ibb.co/X5GRxsH/2-F32-F96-B-0912-4-A4-A-9-F14-AD060-CE065-F6.jp g"/> [/img][/url]
Posted : 28/04/2024 4:19 pm
kayak23, anorak, nuke and 3 people reacted
