And what makes you think I care about the distinction between Israelis and Zionists, that completely misses my point.
You might not care about the distinction Israelis and Zionists but Gonzy obviously does.
I tend to agree with you, I see little distinction between Israelis and Zionists. I consider most Israelis to be Zionists so feel the difference is fairly minimal. In the same way most white South Africans were Apartheid supporters so despite many notable exceptions the two terms were fairly interchangeable.
I do however make a very clear a distinction between Zionists and Jews.
We are veering dangerously into the same territory as the last thread. I do feel like you do, that the blockade needs to be lifted Ernie. But I don't feel that answer is a one state solution and I don't feel the answer is more name calling. Both sides can be called a lot of things, terrorists (see what the Egyptian people think of them) and the Israelis could be accused of acting like South Africa. The thing is, I think that is all completely immaterial to the subject at hand when what needs to be done is that the two sides need to start to understand each other and compromise.
Unless that is, you want to pick a side and let the war reach it's bloody peak until one side is wiped out. I hope that clears things up with you in regards to my opinions.
