Car battery amps
[Closed] Car battery amps
[#4168609]
I've just bought a little screen for a reversing camera for a car. It's meant to wire into the car electrics but i want to use it externally. So what kind of amapage should i be looking for on a 12v power supply?
Posted : 16/07/2012 10:38 pm
Unclear what you mean. Externally to what? What is the 12V supply?
Posted : 16/07/2012 10:41 pm
12v power supply is a plug-in transformer, like thekind of thing used to charge many electronic devices.
Externally means external to the car, like in my house.
Posted : 16/07/2012 10:43 pm
Typically around 5 watts so less than 0.5 amp, but a 1 amp setup would probably do.
Posted : 16/07/2012 10:45 pm
No motors and just electronics, very little I'd think. Does it have a label stating the wattage? If so just use Ohms Law to find amps.
Posted : 16/07/2012 10:46 pm
Oh right.. there should be a sticker on the back giving wattage? Then divide by 12 to get the current requirements.
A car lighter socket can only supply 10A so it'll be less than that. A lot less, most likely!
Posted : 16/07/2012 10:49 pm
Ok, i have a 12v 1A transformer from an old modem, so long it doesn't kill my screen.
No, no wattage,it came from hong kong via the internet
Posted : 16/07/2012 10:53 pm
How does the screen plug in? If it's a thing that goes into the cigarette lighter, there could be a voltage regulator in there. You positive that the screen's 12V?
Posted : 16/07/2012 10:58 pm
No it's a thing which wires up rather than plugs in, yeah it is 12v
Posted : 16/07/2012 11:05 pm
12v 1amp will likely be enough unless its some aweful cheap thing (in which case it will have a 2amp electric heater inside it lol).
Freely available on ebay. Depends what connector you need, but I generally just buy the cheapest thing going and stick my own connectors on it etc.
Posted : 16/07/2012 11:45 pm
BTW average car battery is 40-60aH, but electronic things only draw what they need, its the correct voltage you have to supply them with.
Posted : 17/07/2012 11:12 am
Brickman what is that funny little ad that comes up with your text?
Anyway, plugged it in with a 1A 12v transformer and nothing happened. There is a 2A fuse in lead to the screen, but surely that is just surge protection.
Posted : 17/07/2012 2:17 pm
When you say transformer, do you mean a complete power pack black box thing, or just a transformer on its own?
Posted : 17/07/2012 2:18 pm
Surely he means one of these transformers..
Posted : 17/07/2012 2:24 pm
are you feeding it some video?
Posted : 17/07/2012 2:31 pm
Just a power supply like you used to get as a phone charger
No, not feeding it video yet, wanted to see if it would power up
Posted : 17/07/2012 2:37 pm
I take it there's some sort of power indicator then?
There's plenty of monitors that wont visibly power up without a video source being present
Posted : 17/07/2012 2:39 pm
If its a reversing camera, wouldn't it only operate when you are in reverse? Or as above, no video input, no power on.
Posted : 17/07/2012 2:47 pm
I'd expect the backlight to come on though.
Posted : 17/07/2012 2:48 pm
not on all, the power is triggered by the video
Posted : 17/07/2012 2:49 pm
erm no, no power indicator
Posted : 17/07/2012 2:55 pm
ok so it works with a camera feed
ta
Posted : 17/07/2012 2:59 pm
Ok, just in case people happened to be interested. I just got a Raspberry Pi and was looking to see if i could run it on a mini screen. I can!
Hooray!
Posted : 17/07/2012 3:17 pm
Can you read the text though?
Posted : 17/07/2012 3:51 pm
Some of the time, but not all of the time
Posted : 17/07/2012 4:30 pm
SamCooke - Member
POSTED 42 MINUTES AGO # REPORT-POST
Edit: Respect for having a bash with the Pi - I need to do something with the one I bought.
Posted : 17/07/2012 5:13 pm
