Car audio help need...
[Closed] Car audio help needed
[#8081559]
Why can't I hear my ipad mini when I try and plug it into the Aux on my car stereo, an android phone works fine. Do I need a special cable from Apple or the like?
Stereo is in a Peugeot, bog standard generic thing.
Posted : 29/09/2016 7:47 am
ipad volume is on full and not on mute one assumes?
It should* just work...
Posted : 29/09/2016 8:46 am
What's the 'aux', 3.5mm jack or something else?
Posted : 29/09/2016 8:59 am
have you checked your iPod with a set of headphones? The headphone output is fully analogue - theres' nothing clever going on there - should just work
Posted : 29/09/2016 9:07 am
If you are using a 3.5mm cable into the headphone port it's more than likely this. The headphone volume could be turned right down - so turn it up.
Posted : 29/09/2016 9:15 am
Are you plugging it in via the headphone socket, or the proprietary connector on the ipad?
As above, what's the aux-in on the car? Just a headphone socket, or something more sophisticated...?
Assuming it's a headphone socket, then it will probably be the volume on the ipad. You'll need to whack it up.
Posted : 29/09/2016 9:19 am
Thanks people, Aux is just 3.5 fittings on both.
Will have a proper play today.
Posted : 29/09/2016 9:35 am
On my car, when you are in the Aux setting hitting menu brings up some settings specific to the aux input. One of them is 'level' and there's 3 options of 'loudness' so you can adjust the base volume of the aux input - I guess it just alters the gain on that input.
It might be worth looking at that. It could be that the headphone output of the ipad is a lot lower than the Android device you used, so you might be able to compensate for that if your car has a similar aux level adjust....
Posted : 29/09/2016 9:48 am
