I'm almost finished building a 'Wickey Hill Billys farm', it has been a complete pain with almost nothing measured or pre-drilled, just an expensive pile of wood really.
So we finally get to adding the slide, which is attached with two smallish screws at the top and nothing at the bottom!It just doesn't seem enough, has anyone built similar and done anything to beef up the slide?
two screws is all the slide needs. Decent screws will take 100's of KG in shear and the slide is designed so there's very little force pulling against the screws. The screws are just to keep the slide located on the top rail which is bearing the load of little darlings hooning up and down.
I bought a slide (sounds like the same as yours) and fitted it to a "treehouse" I built 3yrs ago. It hasnt moved or failed since.
[img] https://goo.gl/PJRKEz [/img]
yep, exactly the same. Slide has been in place for 2 years with no issues.
Well that is good to hear, my concerns were mostly about climbing up the slide and potentially lifting up as kids seem to do,
It is the same slide that I have, has nobody anchored the bottom?
No anchor at the bottom of our slide – but it's dug itself into the ground slightly anyway so it is as good as anchored.
And our kids constantly walk up the slide too without any issues at all - in fact I don't know how walking up a slide would cause an unanchored slide to move.
Sounds good, I will just leave it then, thanks all.
Has anyone made a slide? I'd like to make something quite long, i.e about 8-9 ft high (off the banister from a raised bit of decking
The commercially available slides are either nasty or expensive
I looked at making one last year and didn't get very far. I looked at making it out of stainless steel but when I looked at ones on the local park there is quite a lot of details to make them safe i.e trims covering sharp edges and curving bits to mate the sides to the bottom curves. We don't have the machinery or materials at work for the more complex bits so I decided a bought one would be quicker, easier and safer.
Does anyone know where I can get a slide longer than 3m long without buying a proper playground one?
keep an eye on ebay,
I nearly bought a long stainless steel one for a reasonable price but it was too far away. Collection only can be your friend.
