Anyone tried changi...
[Closed] Anyone tried changing their own car tyres?
I don't really want to grumble on about this, but how on earth have we managed up until now? I know Kirklees, I am intimately acquainted with many of the steep back roads and steep main roads, but I can't recall any great number of problems due to people not using winter tyres in the past.
I'm tending towards a large amount of placebo effect, I'm afraid. Most roads might be blocked for a day or so, maybe a bit longer, but again, looking at the overall climate of the UK.... No, sorry, not buying it.
Posted : 14/11/2012 8:49 pm
I would seriously get a spare set of wheels
As above, it's a big outlay all in one go.
I don't understand your point. There is always room for improvement, isn't there?
We managed with no central heating and outside bogs too - I'm assuming your house is set up that way?
If you're talking about ONLY snow our road was covered in ice for about a week year before last. No-one drove anywhere. And I came very close to getting stranded 120 miles from home too at one point.
Then there was my Dad's big birthday bash which we'd have missed last year if we hadn't had winter tyres. Not life changing, but an important family do and I'm glad we managed without any difficulty.
A few years ago my Dad went to hospital in the snow on Christmas morning. We didn't have winter tyres then and we had to drive 25 miles to the hosp ourselves. It was pretty sketchy and took forever.
I could go on.. and then there'll be the time at some point in the future where I have to do an emergency stop on tarmac and I'll just manage to avoid a serious crash because I have super grippy winter tyres on.
Posted : 14/11/2012 8:51 pm
crieky - you've asked the question "does it really make a difference" and had several responses (from experienced drivers) telling you that it does.
I'm currently picturing you like this...
We managed without crumple zones, seat belts and airbags for decades, why bother with them now?
Posted : 14/11/2012 8:54 pm
I had a Mondeo the year before last with Pirelli's on and I had difficulty getting from Rastrick over to Ainley Top. Put winter tyres on for the first time that year and that journey, plus the others, was significantly easier.
You must just be a much better driver than me.
Posted : 14/11/2012 8:55 pm
I remain unconvinced.
Adieu. 🙂
Posted : 14/11/2012 8:59 pm
Luckily, for you, they are not compulsory here (yet)
So you don't have to.
Posted : 14/11/2012 9:01 pm
I've only ever swapped one car tyre (but literally dozens of motorcycle tyres, my record being nine minutes if I recall correctly and I know many who can do it much quicker) and it was dead easy with the right levers, but it was not a very low profile tyre. Google will bring up lots of ways to break the bead with two bits of wood and a hinge - this will do any width of tyre. The use of tyre lubricant helps too.
How dear is balancing at the local tyre fitters?
I'd be worried that the use of winter tyres in "warm" weather months would give the insurance boys a get out in the event of any sort of incident.
Posted : 14/11/2012 9:02 pm
And I'm honestly amazed that you keep logging on to try and wind me up, and that you don't know when to stfu
But I'm right and you know it. 🙂
And the more you tell me to shut up, the less likely I am to do it.
Orange Crush - Member
Do not- it will not happen, the tyres are road legal and work perfectly well in summer.
crikey - Member
For one thing- why put up with it if you don't have to? "Managing" is fine but it's not as good as "not having to manage"
There's also a few things that have changed... Roads are busier, which has all sorts of complex impacts (can't grit a gridlocked road, frinstance). Also typical tyres are, frankly, often less suitable. Fatter tyres don't work as well on snow, and everyday tyres are often pitched on dry performance, long life, low noise. I reckon average tyres today are less good on snow than they were 10 or 20 years ago.
Probably other things too but these are the obvious ones.
Posted : 14/11/2012 9:05 pm
Central heating? How 20th century. No central heating here and 21°C.
The cars of my youth were fine through the Winter. Tyres were between 145 and 165, there were lots of sipes and the rubber was soft (and short lived).
[img] &w=200&h=250[/img]
Current cars run around on semi-slick garden rollers:
[img] https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQKpYdlbEr4vsxuKA1F-TZJUH-PlJ2hz3qGb8BcslyTGT6GOqNugA [/img]
Posted : 14/11/2012 9:06 pm
Crikey,I assume you've put a few miles in on winter tyres in order to decide whether there is a performance benefit, yeah?
Posted : 14/11/2012 9:17 pm
Go on, Crikey, get yourself a set of Michelin Alpins, you know you want to. 8)
Posted : 14/11/2012 9:20 pm
molgrips, is going winter tyres all year round an option? It's what Conti recommend for those who don't want to swap...
Posted : 14/11/2012 9:24 pm
I seem to have managed perfectly well all these years without needing them, so why would I need them now? As above, they are of little use if the roads are blocked by all those people who don't use them.
Meh. You carry on chaps, I'll struggle on through...
(Been driving for 30 years, never, ever, ever been stuck in the snow, largely because I can watch weather forecasts and this is the important bit... adjust my behaviour accordingly.... 😉 )
Anyway, as above, this is dull so I'm away.
Posted : 14/11/2012 9:26 pm
Yes I've done it for years, its not a problem. Just because some guys who at the tyre shop uses a pneumatic device does not mean that you need to. You need limited special tools, its not dangerous, its not highly skilled. Like most things in life there is a knack and some things to look out for but its defiantly within the DIY realm. You can balance the wheels yourself with a static balancer and some care but most of the time you don't need to. The main thing the expensive tools the tyre sop use gain you is speed. Changing a tyre by hand takes more time. Balancing it by hand takes more time.
Even if you don't balance the wheel after its not usually an issue. I'm not a fast motorway driver, fastest I end up is 80 mph and have no problems with unbalanced wheels. Last set of wheel I had to get balance was on a previous car year ago. When I have had problem with a unbalance wheel its easy to sort, in the mean time I just don't drive at whatever speed I experience the resonance. Simple.
You need some safe way of breaking the bead. Our one is similar to [url= http://www.ffx.co.uk/tools/product/Tc968%20Tyre%20Bead%20Breaker%20Tc968%205051747391000%20Tc968%20list ]this[/url]. After that its a case of tyre leavers, rubber mallet and soapy water. Its quite physical and there is a knack. If you're ever near Bournemouth try and contact me and I'll show you.
Posted : 14/11/2012 9:27 pm
can you get random individual alloy wheels on ebay? you could get a cheap non-matching set, it wouldn't matter if they look odd because as long as they work (all the right size), no-one looks at your wheels in winter and they get scratched/dinged anyway ? just a thought
Posted : 14/11/2012 9:32 pm
wow, who'd have thought winter tyres would get such an argument going, but then it is STW after all.
Must admit i swap to winter tyres every year, spend much time driving in the highlands in a BMW so it does help.
As for how we managed with out well true we did, but equally we managed with out www and mobiles, but could we now? I mean i might have to go and find something more constructive to do than type shite on the internet from my smart phone 🙂
Posted : 14/11/2012 9:49 pm
(Been driving for 30 years, never, ever, ever been stuck in the snow, largely because I can watch weather forecasts and this is the important bit... adjust my behaviour accordingly.... )
This reminds of of something my driving instructor told me.
"The worsts drivers on the roads are blokes who have been driving for decades, think they've got everything right but really haven't"
Posted : 14/11/2012 10:00 pm
What thebrick said, you need :
a.Tyre changer similar to Sealey TC960 , can get them with air powered bead breaker - much faster.
b.A compressor
c.tyre soap
d.practice
you can balance yourself or mark the rim, and note what weights were where and put them back in the same place.( new weights buy them from tyre place)
That will cost you £200 or so and help with your tubeless bike tyres
Posted : 14/11/2012 10:22 pm
Edukator has it spot on.
20 years ago most cars had winter tyres on from the factory - they just weren't called winter tyres. They now have stupid wide rock hard noisy slicks
This thread needs surf-matt 🙂
Posted : 14/11/2012 10:24 pm
You're right, young inexperienced drivers are far safer, insurance companies know nothing.
Posted : 14/11/2012 10:25 pm
I'm a crap driver, but on the positive I haven't had an accident for over 20 years.
Posted : 14/11/2012 10:26 pm
and as if by magic
[img] ?w=700[/img]
you would be better not putting any weights on at all than doing that, every tyre has different heavy spots in the same way a rim does
Posted : 14/11/2012 10:30 pm
You'll notice it was in quotes.
Strictly speaking she was referring to (really) old boys
[you would be better not putting any weights on at all than doing that, every tyre has different heavy spots in the same way a rim does]
I am saying same rim to same tyre in same rim/tyre fit = as they were originally
Posted : 14/11/2012 10:35 pm
Last year, the A470 was blocked at the reservoirs on the steep bit with stuck drivers slithering everywhere. So I turned around and went over the top to Hirwaun, in 6" packed snow.
I had more options due to my tyre choice.
TheBrick and others - good advice, thanks. I'm now considering it 🙂 I've long wished for a compressor for a variety of reasons, so this coul dbe a good excuse.
Posted : 14/11/2012 10:39 pm
What about this for a bead breaker?
http://www.machinemart.co.uk/shop/range/guid/25C43A90-03F7-43AB-8754-3FD08E562668?da=1&TC=SRC-bead+breaker
Posted : 14/11/2012 10:44 pm
[url= http://www.demon-tweeks.co.uk/motorsport/workshop-equipment/sealey-manual-tyre-changer ]This looks useful[/url]
Posted : 14/11/2012 10:49 pm
Always half measures molgrips.
[url= http://www.tyrebaydirect.com/ThinkSmart_Leasing.html ]Feast your eyes on this.[/url]
Posted : 14/11/2012 10:52 pm
Why don't you just go and wait outside the tyre place at going home time and see if you can put the bite on one of the fitters to do it for pocket money?
Posted : 14/11/2012 10:53 pm
That machine mart tool looks like it's got more sense than the strategically shaved Gorillas that work in my local Kwik Fit
I changed quite a few on my old Landrovers (steel rims) I wouldn't touch car tyres on alloy rims though..
Posted : 14/11/2012 10:54 pm
I'd say no. I've broke a tyre bead with a bolster and and a lump hammer before (more or less what you're proposing there) due to emergency in the middle of France and it is tough. You need some sort bead breaker with a long lever. Even with that you still regularly have to move round the tyre a bit at a time.
Posted : 14/11/2012 11:00 pm
In 1974 my dad bought a Moskvich. It came with two enormous tyre levers and the trackpump from hell. No doubt in Russia it was expected that you would be changing tyres yourself.
Needless to say, we had a go.
Once.
And there are threads on here about getting tubeless bike tyres to seal...
Yeah but I never have any trouble with that 🙂
Looks like the gear would cost me £250 ish.. so maybe I'll just pay the man this time..
Posted : 14/11/2012 11:07 pm
Lols @ this thread
Most stwers can't fit a UST tyre properly on their bikes yet happy to change their own car tyres 😆
Posted : 14/11/2012 11:08 pm
You need to buy a cheap set of rusty old steelies to mount your 8 winter tyres on, go to your local quickfit type place with tyres and rims in your boot and ask if they want to do a quick cash guvvie. 20 quid will probably change hands for the swap. Have used this method a few times. I do an 80 mile commute, 5 days a week in North Yorkshire. Trust me, you dont need winter tyres in the uk. Just learn to drive 😉
Posted : 14/11/2012 11:17 pm
Just go into some local tyre places near you... Be nice, tell em your dilemma wave a few pound notes (yes I know ! ) and I'm sure you will get some decent offers. No really !
Posted : 14/11/2012 11:52 pm
wave a few pound notes and I'm sure you will get some decent offers. No really !
Do you think this will work for having the tyres changed too?
Posted : 15/11/2012 12:01 am
you know what? that we dont have pound notes any more?
Posted : 15/11/2012 12:17 am
We do in civilisation
Posted : 15/11/2012 12:20 am
when did you last get one in your change though? - I've not seen one for years
Posted : 15/11/2012 12:25 am
For the Prius : http://bit.ly/TJW1Tz
For the Passat : http://bit.ly/PV4m8S
Job done.
You need to pay the initial cost, but its less than what you said you are currently spending every year to change them.
Posted : 15/11/2012 12:29 am
Page 3 / 4
