zero spacers under ...
[Closed] zero spacers under stem - ok?
[#4962892]
I have a Fox Float 180mm fork with a tapered steerer, I have come to fit it to my new frame but when inserted through the headtube and used with a Easton Havoc Stem and no spacers underneath, the top of the steerer tube sits 3mm below the top of the stem - is it ok to use no spacers at all?
Posted : 15/03/2013 11:05 am
Yes it's fine.
Posted : 15/03/2013 11:06 am
I'd call that a perfect fit. 8)
Posted : 15/03/2013 11:13 am
Yes, why wouldn't it be?
Posted : 15/03/2013 11:17 am
I'd put a small spacer above the stem but otherwise it'll be fine.
Posted : 15/03/2013 11:34 am
It'll be fine.
Although it's worth checking whether your brake levers and/or shifters smack the crossbar when your bars are turned past 90 degrees. Could be worth a 3mm spacer under the stem if you think damage could be done if your bars get spun round that far.
Posted : 15/03/2013 11:42 am
I like to use a small spacer (~1mm) just to make sure the stem isn't pushing on the top cap in a funny way but it will be fine.
Posted : 15/03/2013 11:54 am
That would mean the steerer tube ends 6mm below the stem - is that really okay? Where would you draw the line?
Posted : 15/03/2013 11:58 am
Yep, slam that stem.
Posted : 15/03/2013 12:03 pm
if youre running a particularly short stem and have a particularly large diameter headset top cup they could interfere, so check that. otherwise go for it.
Posted : 15/03/2013 12:20 pm
If the steerer is 3mm shy of the top of the stem with no spacers, I would not put any spacers underneath.
The top of the steerer must be above the centre line of the top clamping bolt of the stem. IIRC Easton and Thompsen recommend that if the steeer is shy of the top of the stem there is a limit of 3mm max, so as said above,it sounds like you have a perfect fit without using any spacers
Posted : 15/03/2013 12:30 pm
Ah, yeh. Probably too much of a difference then.
Posted : 15/03/2013 12:42 pm
Have you just assembled it or have you preloaded the bearings? You might find that that 3mm reduces when you tighten up the top bolt.
Posted : 15/03/2013 12:43 pm
Depends if the bike still fits you .
Posted : 15/03/2013 2:27 pm
Oh a slam that stem - one of the most rediculous fashions this decade - somewhere down beside lumo pink paint jobs
Posted : 15/03/2013 2:28 pm
trail_rat - sounds like he has no choice due to taller stack height on new frame?
Posted : 15/03/2013 2:31 pm
Oh yes , wasnt directed at him - largely the slam that stem content
Amount of folk that would come into the shop with a sore back
Why is your steerer so short ?
Xyz pro has his like that.
Posted : 15/03/2013 2:34 pm
Fork was taken from another bike so I don't get any choice over stack height but I can run a 1mm spacer with a Spank Spike Race stem [35mm stack height] with 2/3mm gap between the top of the stem & the top of the steerer tube.
Thanks for all the replies.
Posted : 18/03/2013 12:37 am
