XTR M980 HTII BB - ...
[Closed] XTR M980 HTII BB - any good?
[#7663479]
Have always used XT/Saint without any problems just wondered if XTR was better/weirder in any way.
I understand the cups are smaller and there's a plastic adaptor - does this work OK
Posted : 22/02/2016 10:36 am
Bumpety bump
No one used an XTR BB?
Posted : 25/02/2016 4:12 pm
its fine. works ok and lasts a little longer than the xt one. issues ive had is the plastic tool can wear / not fit some cheap bb spanners and it leaves a bit of exposed alu frame where as the xt one coveres it.
taken a couple apart and they have better seals than the xt and you cant re pack them without destroying them. you can with the xt.
Posted : 25/02/2016 5:23 pm
Pretty much the same as XT in my experience, they're made a little different but I'm not sure it translates into any real benefits.
<gusset ext24 recommending bot mode> gusset ext24 is good. Comes in pretty colours, lasts better than XT if unserviced, lasts quite a bit better than XT if serviced, and takes standard bearings when they wear out. Ceramic one seems to be a bit crap mind.
Posted : 25/02/2016 5:38 pm
If you can get them £20ish,happy days! there black,small and seem to last well.got a few around this time last year, when they were £16.Still on the first one
Posted : 25/02/2016 6:45 pm
Thanks fellas have a good one
Posted : 26/02/2016 10:11 pm
