Looking at getting some new brakes but can't get a post mount rear caliper in XTR.
I know standard disc size for post mount is 160mm, but will rear IS run 140mm?
Help please
Posted : 28/05/2010 11:03 pm
its just IS rear isnt it? and that should be (with no adapter) 140mm?
edit:on the rear only
Posted : 28/05/2010 11:20 pm
Thanks
Posted : 28/05/2010 11:37 pm
If you fit a specific rear caliper then you run a 160mm rotor. However if you fit an IS front caliper on the rear then you run a 140mm rotor.
Posted : 29/05/2010 6:26 am
