Hi, Does any one know the difference between an XT M756 Rear hub and a XT M756A rear hub? More specifically are the freehubs interchangable?
tried techdocs?
here we go,
A type
Looking at that I'd say yes, although the spacing may be a bit out as the cone/lockrings are different on the DS.
Had a look on Techdocs and shows M756 listed
Cheers, Thanks for your help missed the difference in doc names...
As long as the actual hub is the same I can transfer everything else from one to the other...
An update for anyone interested...
There are differences between the hubs, the bearing seals are different so a bit of mixing and matching is required. needed to keep the old axle race on the non drive side but the new one on the drive/freehub side.
Same applies to Deore 525/525A if anyone's interested in swapping bits on those as well.
