XT Brake Problem
[Closed] XT Brake Problem
[#7220141]
Pair of XT brakes just over a year old. Last month the rear suddenly had no power and squealed like a banshee. However they came back after dragging them down a long hill. Contaminated Pad / Rotor I though. Must have got a bit of lube on them.
Cleaned the rotor and pads and they worked a treat for the one ride. Put bike away and next time come to use it and same problem. I've bled them also.
Again, dragged them down a long descent and they were fine for the rest of the ride, then once again... next ride they are the same.
Any ideas what may be causing it ? I cant see any brake fluid on the calliper.
Cheers all.
Posted : 27/07/2015 11:30 am
Could be that you have a small leak from the piston behind the pad. It wouldn't take much brake fluid to make them squeal. Might be a warranty job.
Posted : 27/07/2015 11:33 am
Possibly a daft thought.
What size rotors and what terrain? If they're huge rotors, you could be glazing the pads on the less hilly terrain, when you hit the long downhill they start to work properly.
Posted : 27/07/2015 12:17 pm
180's and ordinary riding, well, lakes riding.
Posted : 27/07/2015 12:23 pm
 hora
Strip and new seals etc I'd say
Posted : 27/07/2015 12:33 pm
Didn't think you could get spares/seals for Shimano brakes.
Posted : 27/07/2015 12:37 pm
When I had leaky callipers there was a minute amount of leakage but it had a significant reduction in braking performance. Took me ages to spot the leak as it was so small. After the ride, take the pads out and give the calliper a good clean around the pistons and seals. Then zip tie some tissue to the pistons or tightly wedge the tissue so its got a good contact with the piston seals. leave over night. If there is any leakage there will be some staining on the tissue.
But ... if the callipers are leaking then the lever will start to feel softer and pull back to the bars. Especially for the first few lever pulls, after which any air in the calliper may have moved up to the reservoir. If the lever feels consistently firm then I think something else is happening.
Posted : 27/07/2015 12:46 pm
Lever feels fine. Good Tip Jairaj.. thanks mate, will give that a go.
Posted : 27/07/2015 1:09 pm
[url= http://forums.mtbr.com/brake-time/xt-xtr-brakes-get-squeal-power-loss-after-sitting-idle-6-8-weeks-902792.html ]Seems I'm not the only one.[/url]
Posted : 29/07/2015 9:49 am
I'm utterly fed up with my XT brakes. They were fine for the first few months and then they've just been gash since. I've tried about five different types or brands of pad, every trick going to get any last bits of air out, but to no avail. Pretty disappointed with them.
Posted : 29/07/2015 10:45 am
I have a similar problem with my Deore. Worked perfectly for about a year then developed the symptoms you describe. I've just bought a new caliper from CRC for about £20 to swap out, hopefully that will solve the problem.
I quite fancy swapping to Hope, but can't justify the price differential as the Deore's did work flawlessly for a long time.
Posted : 29/07/2015 10:49 am
Fixed mine after a thread on here (explained the tiny leak phenomenon) - bought some aftermarket hoses. Jobsagoodun.
http://www.uberbikecomponents.com/category/435/Hydraulic-Brake-Hose-Kits
Posted : 29/07/2015 10:52 am
