will this work?
[Closed] will this work?
 StuF
[#9408505]
Off to the alps in the summer, only 1 bike allowed so the road bike is coming with me but I'm tempted to try lowering the gearing from the current 34-28 to 34-30 to give me a better bail out gear.
Could I take a 30 off my tiagra 10 spd cassette and add it to my 105 11 spd 11-28 cassette (removing 1 of the smaller sprockets)?
Will the 11spd chain go on the 10spd sprocket or will it just jump around horribly?
I thought I'd ask on here before spending time trying it.
Thanks all
Posted : 29/06/2017 1:19 pm
34-28 to 34-30
that's such a small difference it will barely be worth making
possibly, if you take the single 30t cog off your Tiagra, if you lose the 11 you'll need a different lockring, if you lose something else you'll have an annoying jump, also see above, probably not worth it
Will [i]probably [/i]work, for a given value of 'work' but again, see above.
Basically it's an awful lot of bodgefaffery for minimal if any gain.
Whack a 11-32 (or bigger) cassette on, or man up. Where do you normally ride? Road climbs in the Alps aren't normally steep, just long....
Posted : 29/06/2017 2:27 pm
No. The top 4 or so cogs on the cassette are attached together, not separate.
Posted : 29/06/2017 2:30 pm
Not on any of the Tiagra* cassettes I've seen, they'll all individual cogs and riveted though, grind/pop the rivet and they come apart.
*HG50/4600 and earlier, might be different on the new 4700 but I don't think so...
Posted : 29/06/2017 2:35 pm
 StuF
Sounds like a dose of mtfu to save a lot of bodging. 🙂
Usually ride around south east peaks / belper so more used to the short steep stuff.
Posted : 29/06/2017 2:48 pm
 Bez
You'll be fine. If it all gets too much the worst case scenario is you just sit and enjoy the view for a few minutes.
Posted : 29/06/2017 2:53 pm
So joined together then 🙂
Posted : 29/06/2017 3:00 pm
Ah! I thought you meant like 105+ on an Alu carrier where you can't separate them, but yes I see what you mean, they are joined, but not like the posher ones.
Posted : 29/06/2017 3:18 pm
