Will there be a Shi...
[Closed] Will there be a Shimano Rival to XX1?
[#4654264]
Just looking at XX1 stuff and wondered if anyone had heard rumours of a Shimano equivalent or rival?
Seems to be that SRAM/Shimano usually offer direct competition to each others recent developments even if release time is not the same-e.g Shadow+ Vs Type 2 mechs, 10 Speed etc etc
So any work of Shimano 11 Speed? 12 Speed???
Posted : 15/12/2012 10:19 am
Dura Ace is going 11spd, so it'll be in the pipeline no doubt. Campag have had 11speed for a while. Alfined 11spd already if its just about gear ratios.
Posted : 15/12/2012 10:27 am
I don't think Shimano will do anything quite like it. They'll go 11 speed, but I don't think we'll see the same design stuff, with the proprietary freehub body and that.
No fact behind it, just what I suspect.
The whole 'you shouldn't need a chain guide, unless you do', isn't very Shimano either, they'll just do something more 'safe' that works perfectly for everyone.
I think a winning idea would be to keep it 10 speed using existing hubs but have a wider spread of gears.
Posted : 15/12/2012 10:28 am
Or go 11 speed with existing hubs and a wider spread of gears. If it can be done, which I'm not totally sure about!
11 speed road freehubs are wider, but fit in the same dropouts. 11-42 cassette would be good, on a standard (ish) freehub body.
Posted : 15/12/2012 10:33 am
I think 2x10 works so well and really can't see what advantages 1x10 gives? I've used 1x10 in the past but always end up back on 2x10. I found the lower jockey wheel and chain would wear out very fast and for the small weight saving can't really understand it.
Posted : 15/12/2012 10:43 am
The advantage of 1x10 is that you dont have to put up with nasty horrible front mechs. It's the range of gears that's important to me. I run an Alfiine 8 btw but would be tempted by a 1 x 10 (or 1x9, 1x8 etc) if there was a wide range of gears.
Posted : 15/12/2012 10:47 am
A well set up front mech is neither nasty or horrible, getting a wide range of gears is something 2X10 does very well for the average rider.
Posted : 15/12/2012 10:55 am
Gives the gears I want and saves half a pound?
I liked 2x10, but found myself riding in the big ring 95% of the time, but often at the top of the block, smaller single ring, sorted.
Posted : 15/12/2012 10:56 am
I'd happily run an 11spd rear cassette with a smallest tooth of 11t, so it fits on a normal freehub.
The benefit to me comes at the other end of the cassette. If they can make that work, it would be a better way of doing it, rather than pissing around with groupset specific freehubs.
Posted : 15/12/2012 11:01 am
Hob Nob - Member
I agree, I'd love to ditch the granny but haven't got the legs to do so, so adding a bigger sprocket would be a big benefit I think.
Posted : 15/12/2012 11:32 am
