why does my new pin...
[Closed] why does my new pinnacle arkose have no hole in the fork crown?
[#6799494]
I thought I'd seen a thread in here about the pinnacle arkose now having a hole in the fork crown to allow fitting of mudguards? (But that some didn't).
So how come the arkose 4 I picked up yesterday doesn't have one? I thought the issue had been resolved and I forgot to check whilst at the shop?
Posted : 22/01/2015 9:57 am
 Andy
It has (well my 2015 SS does) a threaded hole in the underside of the crown, needs a slightly different attachment method. i.e. A hole drilled through the guard or the normal L shaped bracket bent flat (which is what I think I will do as a hole might weaken the guard)
Posted : 22/01/2015 9:59 am
There was one batch of 2014 bikes that were delivered without them. The 2015 fork has an M5 under the crown rather than a brake-hole style mount.
My SKSs are mounted with the L bracket removed and a hole drilled front and rear on another bike, has done a lot of miles w/o any issues. It's a fairly common way to mount them. Just don't drill too fast as it heats the plastic up and deforms it. Next time I'll try using a blade to wear a hole rather than drilling it.
Posted : 22/01/2015 10:02 am
 Andy
Ah thanks James. btw the Singlespeed I bought is superb - must do a write up and give you some feedback on a couple of things.
Posted : 22/01/2015 10:13 am
Sure, thanks Andy. MIP or via here, no probs.
Posted : 22/01/2015 10:59 am
Ah that's cool, I didn't think to look underneath!
Posted : 22/01/2015 1:15 pm
