Who's riding a...
[Closed] Who's riding a Hope Pro2 with a 10mm bolt in axle?
[#2697752]
As above, how do you find it compared to QR?
Anyone replaced the SS bolts with Ti?
Posted : 27/04/2011 6:40 pm
I guess its stiffer in reality but in my mind its way way stiffer than QR and therefore way way better.
Posted : 27/04/2011 6:50 pm
I've got the superstar both thru thingie, and also the DTSwiss one
It definitely made a difference on my single pivot bike
Posted : 27/04/2011 6:51 pm
i'm on pro 2 evo hubs with superstar 10mm quick release. it is infinitely stiffer than a standard qr but will just about still fit in the drop outs.
Posted : 28/04/2011 9:13 am
I am running Pro II with the bolt up hub. Deffo stiffer, can't say I am overly worried by the weight of the 2 bolts but Ti I guess would save a few grams.
I have been pleased with the setup but if I was to say anything negative about it is that the 10mm bolts can be tight in certain drop outs and (due to a cheap mech hanger) I had to completely undo the bolt on one side to get the wheel in and out.
However, I have since changed the mech hanger and all is OK now (did this only last night).
Posted : 28/04/2011 9:33 am
The only downside of the 10mm bolts is that the head seems to be made of a cheese-like material. Only my profiled Wera 6mm hex key will work them without distorting the interface. Even decent keys like Bondhus will easily start to make a mess of them, especially if I'm in the least bit careless/ham-fisted. If you only ever use a multi-tool, I'd recommend carrying a spare pair of bolts on rides, just in case you manage to round one out in the middle of the woods.
Posted : 28/04/2011 9:41 am
