Which shadow+ rear ...
[Closed] Which shadow+ rear mech?
[#6725050]
Just been refunded for an XT shadow+ mesh under warranty.
Do I just go ahead and order another XT one or are any of the others lower down the range just as good?
Posted : 23/12/2014 3:46 pm
If running 1x10 you could go for a Zee FR which works on 11-36 cassettes.
Posted : 23/12/2014 3:47 pm
May work, won't always- depends on the chaingrowth in the bike design.
The only practical difference i noticed between my slx and xt was that xt had bearing'd jockey wheels, SLX had bushings. But I don't think that actually matters- it did with older Shimano but the bushings will probably outlive the wheels
Posted : 23/12/2014 4:00 pm
Cheers northwind that's the kind of info I was after
Posted : 23/12/2014 4:09 pm
I'd say that the XT was better built than the Zee. The lever arm for instance ( which bent on my Zee) is a nicer cast type rather than pressed.
Posted : 23/12/2014 4:33 pm
I like a Zee just because it is so small and avoids crap.
Posted : 23/12/2014 4:35 pm
i find slx+ better value no difference at all from my xt+ all med cage (shifter plays big part of this i guess) didnt find love for the zee, maybe because i have 40t cog and dont't shift as crisp as slx+ xt+
Posted : 23/12/2014 4:46 pm
If anything I think the SLX parallelogram is stronger due to the extra weight in it.
Posted : 23/12/2014 4:51 pm
I got a deore from Merlin when it was £20 and I know it might hit a rock on any of my regular rides. SLX seem good value to me. I had an XT but that exploded when i hit a drop and it landed on a rock.
Posted : 23/12/2014 4:55 pm
YoKaiser - Member
I'd agree with that, it's definitely nicer. But does it matter, other than on the scales? Not sure. I still fitted XT, because I'm a tart. They both seem pretty impressively tough though, clutch mech aside.
I've a feeling the Zee's overall survivability is a bit compromised by the saint parts- like they're too strong for the SLX parts so the weakest part breaks, where normally the entire mech would give a bit
Posted : 23/12/2014 5:00 pm
Slx medium cage has been flawless for me and imho looks better/cleaner than the xt one. Only problem is it has got a small water trap on the back 😯
Posted : 23/12/2014 5:19 pm
