Which headset for C...
[Closed] Which headset for C456?
[#6660168]
To fit 1 1/8" forks, is this the correct item?
http://www.planetx.co.uk/i/q/HSOOSR/on-one-smoothie-regular-headset#reviewstabs
From the pics it looks like the bottom cup is for a tapered head tube but is reduced drastically internally
Posted : 25/11/2014 2:02 pm
Definite no on that one. That is a standard 1 1/8th headset for old style head tubes - ie the most common type until taper steerers took off.
you need the on-one smoothie mixer but not sure if it comes with a crown race for straight steerers. If not you can either buy the crown race or buy the hope crown race adapter.
Personally i would go with a hope pick and mix headset and the hope crown race adapter. Or the superstar taper headset I have in mine came with both crown races and has been fine. Would have preferred the Hope but wasnt out when I needed it.
Posted : 25/11/2014 2:17 pm
This is the on one headset you need: http://www.planetx.co.uk/i/q/HSOOSMTAPER/on-one-smoothie-mixer-tapered-headset
looks like it comes with the crown race for the 1 1/8th steerer so you would need to buy a new crown race in future if you switch to tapered. Problem with that being is it has to be available. For that reason I would go with Hope or Superstar.
Another option on a regular C456 is a Works components angleset type headset to give you the 'Evo' geometry.
Posted : 25/11/2014 2:20 pm
Thanks for the in depth response there andyl! The bike is coming with a hope headset, I was under the impression a different bottom cup was needed to fit standard steerers. £8 adapter it is then, happy days!
Posted : 25/11/2014 4:57 pm
yep, stick with the Hope headset if you can, the On One Smoothie Mixer HS aren't that great.
Posted : 25/11/2014 5:22 pm
IIRC Hope did an early lower cup that looked horrible and was external type but step down to 1 1/8th so it actually went narrower than the C456 headtube. They then switched to the external 1.5" type and a step down adapter instead of opting for a large oversize crown race like some do - I prefer the Hope approach.
So you may not need anything if it is the early type and the previous owner had a straight 1 1/8th steerer or you may need the cheap adapter (should be around £8 from memory). It's a HS136: http://www.chainreactioncycles.com/hope-tapered-1-5-reducer-crown/rp-prod71609?utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom&gs=1&gclid=Cj0KEQiA7tCjBRDulMny5rfM0dkBEiQA7fcshV47iIaMzoCI5W7HwrMvbQoRhDEJqJEe6qrnEQpYmTkaAmGN8P8HAQ&gclsrc=aw.ds
Posted : 25/11/2014 6:04 pm
