Which GPS?
[Closed] Which GPS?
[#6178371]
I currently use a Garmin 305 specifically for the bike but I'm finding it's starting to lose GPS more and more recently so need a replacement.
I'm also doing more running so looking for a GPS to do the best of both, what's out there?
Posted : 09/05/2014 4:27 pm
The free one on your phone?
Posted : 09/05/2014 4:28 pm
The phone isn't robust enough for falling off bikes and getting wet on soggy runs. Plus I'd need an add on for Heart Rate Monitoring.
Posted : 09/05/2014 4:32 pm
Garmin 510. You can set up different bike profiles on it. Can use HR and cadence meter info if you have those. You can get a bundle with the main unit, HR monitor & strap and cadence pod.
Posted : 09/05/2014 4:38 pm
I can't fault my Garmin 510 for stats (distance, elevation, HR etc), and navigating from a tcx/gpx file works well for the most part. Sometimes I wonder whether I should have gone for the more expensive 800/810 to have the benefit of maps but it's significantly more money when you factor in the cost of maps.
Posted : 09/05/2014 4:52 pm
