Which fork oil?
[Closed] Which fork oil?
[#892799]
looking for some 15wt oil for my RS reba forks, any recommendations? The SRAM stuff is around £15 a bottle!
Posted : 24/09/2009 6:38 am
Go to a motorcycle shop
Avoid anything that claims to have things like 'seal swell' in it
Posted : 24/09/2009 6:52 am
 nuke
I got this oil from CRC for my RS forks...
http://www.chainreactioncycles.com/Models.aspx?ModelID=8399
Posted : 24/09/2009 7:24 am
I bought 2 ltr of motorbike fork oil for £16 a 10w and 20w 50/50 mix of each gives you 15w (they did not stock 15w)
400ml from my lbs cost £16
for the same stuff
if you live near taunton I will give you some
Posted : 24/09/2009 8:32 am
Apparently - Rockshox [bizarrely] re-brands Torco RFF 20 as RS15
http://www.peterverdonedesigns.com/bikesuspension.htm
Posted : 24/09/2009 9:03 am
Either fork oil from a motorbike shop or the stuff from CRC in the grey bottle with green lid is quite reasonably priced.
Posted : 24/09/2009 9:07 am
 Del
as above - motorbike shop. got 500ml for less than a fiver - castrol iirc
oh - and if your brakes use dot 4 or 5.1 brake fluid get some o that while you're there 😉
Posted : 24/09/2009 9:20 am
